Battery voltage readings
Old Jul 25, 2011 | 02:59 PM
tinman565's Avatar
tinman565
I have a Scan Gauge II....what are you guys (that have the same unit) seeing for displayed battery voltage readings while running ? Thanks.
Old Jul 26, 2011 | 06:49 AM
NewToDiesels's Avatar
NewToDiesels
I was at 11.5 to 13. Just replaced a dead alternator and now it stays pretty much pegged at 13.8.
Old Jul 26, 2011 | 03:15 PM
Risk176's Avatar
Risk176
Scanguage reads 13.6-13.8, have seen 14.1 or 14.2.
Old Jul 26, 2011 | 06:23 PM
tinman565's Avatar
tinman565
Ok...so has anybody upgraded to a larger alternator ? I have seen 160 amp...200 amp...and 220 amp units.
Old Jul 26, 2011 | 06:35 PM
69cj's Avatar
69cj
A stock alternator with good fully charged batteries can read as low as 13.1 to 13.4 and be perfectly OK. When the batteries need charging it will increase to the upper 13's, lower 14's. Mine runs in the low 13's fairly often and when I check the static voltage after sitting all night the batteries read 12.7 volts. You won't get any better than that. I would venture to say that many a good alternator were trashed before their time.
Roger T. Pipe
Feb 28, 2010 01:41 AM
avator
1997 - 2003 F150
13
Dec 1, 2008 10:49 PM
1mtr23
1983 - 2012 Ranger & B-Series
Oct 28, 2007 04:25 PM
DRanchero
Electrical Systems/Wiring
Mar 15, 2007 12:01 AM
bsmith8
Jan 5, 2004 05:27 PM
