Gear Ratio Question
Old Jul 25, 2011 | 11:43 AM
Blackdog 15's Avatar
Blackdog 15
Gear Ratio Question
I just bought a wrecked 97 F250 HD with the Powerstroke/4 speed auto trans. It is 2 wheel drive extra cab short bed....I am using the engine & trans to re power my 89 F350 dually flatbed that has a very tired 7.3 diesel...I am trying to figure out the gear ratio in the 97 F250... The code tag on the rear end is as follows:
S 132 P
L 10 10 2 7L 13
any help would be appreciated..
Old Jul 25, 2011 | 11:54 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
It could be 4:10 or 3:55 and both w or without a limited slip
Check with a VIN decoder
Old Jul 25, 2011 | 12:15 PM
Blackdog 15
i looked on line for a VIN decoder...tells basics of truck but no gear ratio info
Old Jul 25, 2011 | 12:27 PM
Copedawg's Avatar
Copedawg
Old Jul 25, 2011 | 12:38 PM
Blackdog 15
Thanks Copedawg....worked like a charm...truck has a 4.10 rear ratio...same as F350 the motor/trans are going into....
Old Jul 25, 2011 | 01:18 PM
dclack's Avatar
dclack
This site says it's a limited slip as well... Ford Rear Axle Assembly Identification - Page 10 - FORDification.com
Are you changing the rear axle too?
Old Jul 25, 2011 | 02:46 PM
Blackdog 15
No, I really want to swap out the 4.10 in the F350 for a set of 3.55 gears though.....I don't do any towing...am planning on over the road open freeway driving delivering parts back & forth from CA to AZ once a week....I carry from 1,000 to 2,500 lbs on the 12 foot flatbed....figure, the truck will have a big HP increase with the Powerstroke over the old 7.3 non turbo....and with the price of fuel....better milage won't hurt my feelings....I drive light on the throttle so the higher gears will be ok.... so once I'm done pirating the motor & trans, computer, etc, I'll sell off the rear end out of the F250...
thinksnow
Sep 14, 2013 01:31 PM
OutlawNomad
Apr 9, 2012 09:59 PM
tunaluvr
Oct 24, 2008 12:08 AM
1L243
Jul 19, 2007 05:27 PM
dieseldoc
Nov 22, 2006 08:36 AM
