Gear Ratio
Old Feb 24, 2007 | 01:42 PM
1L243's Avatar
1L243
Gear Ratio
I have a 1999 F250 Super Duty 7.3 diesel with 2 wheel drive and automatic trans. How do I find out what gear ratio I am running?
Thanks
Doug
Old Feb 24, 2007 | 01:48 PM
travis dasher's Avatar
travis dasher
Stock should be 3.73. Mine is a 99 and 3.73 is what I have, but it is 4x4 I do not know if the gear ratios are different from a 2 wheel drive vs 4 wheel drive. I am pretty sure they are the same.
Old Feb 24, 2007 | 01:56 PM
TwelveAlpha's Avatar
TwelveAlpha
https://www.ford-trucks.com/forums/4...lder_____.html
that tells you what your tag means
http://rides.webshots.com/album/556995120ScfdhR
that shows you how the tags are placed so you can find it
Old Feb 24, 2007 | 03:53 PM
1L243's Avatar
1L243
That information is helpful is the vin # and vehicle certification label the same? If not where would I find the vehicle certification label? I checked over my vin and I have a C8 in it but that does not seem to be on the list.
Thanks
Doug
Old Feb 24, 2007 | 04:04 PM
1L243's Avatar
1L243
Found it on the door post. Looks like I have a 3.73 limited Slip
Thanks
Doug
Old Jul 19, 2007 | 03:05 PM
John M T's Avatar
John M T
mine was stamped on a metal tag attached to the rear diff.
I have a 99 7.3 crew cab long bed duallie. I have 4:10 gears
Old Jul 19, 2007 | 05:27 PM
Layson's Avatar
Layson
Thanks
Doug
I would check the tag on the axle too...
dougjohnson72
Nov 14, 2014 09:07 PM
dhatfield6
Jan 21, 2013 06:31 PM
Firemudder
Apr 13, 2007 12:48 PM
DougD
Jul 23, 2004 09:03 PM
