Oil Pump Clearance Test
As you can see from the chart below, I went from a loose tolerance pump (#1) and went to a tighter tolerance pump (#2) by using different gerotor parts, but the same housing and relief valve.
Also, Pump 1 had some scratches and scuffing on the lobes of the rotors. Pump 2 did not.
I did a test drive, and once the oil was up to temp, I checked the oil pressure at idle, at 2000 rpm and at max pressure. In all cases, the oil pressure was exactly the same with Pump 2 as it was with Pump 1.
My conclusion is an oil pump can wear a bit, or even get minor scratches from debris, yet still provide oil pressure as usual.
Good info though. The pump is usually NOT the issue with pressure, it's the bearing clearances AND rocker shaft clearances that all add up to a big gaping hole.
And, pushing the oil through the filter doesn't help pressure neither.
First of all, it is a HV pump, and I have done some oiling mods which include opening the passage from the pump to the filter, alignment of some of the main bearing holes, plugging off the lifter galleries (am running solid lifters) and restrcting oil to the rocker shafts. I am also running 0.0025" main and rod bearing clearances.
My engine yields the following (hot) oil pressures:
800 rpm idle 13 psi
2000 rpm 43 psi
max pressure when relief valve opens 85 psi
I can get about 2 psi more when I use my System 1 oil filter compared to the M301 I am currently using. By the way, the M301 is the least restrictive paper oil filter I've found to date.
My experiment was to see if I could reduce the little dip (red-line) that occurs at lower rpms in hte chart below, thus raising the oil pressure at idle a little bit, but there was no change.
Sort of makes me wonder what good blueprinting an oil pump does, other than changing the relief spring. All that end play clearance adjustment and de-burring they do... perhaps the deburring helps keep the oil from becoming aerated, but so far, it seems spending money on a blue-printed pump isn't worthwhile.
If by clearance, you mean rocker shaft to rocker arm clearance, I never checked it, but they arn't loose and seem to fit appropriately.
This is my 3rd engine, all with the same oil pressure. First block cracked, second engine destroyed a piston (I adjusted timing IAW a slipped balancer. $$$ mistake).
I've used both home-made 0.090" restrictors and am currently using FPP restrictors. No difference that I can recall.
I've never run the engine with a valve cover off as it's quite messy. During a moment of ruthlessness, I threw out some old valve covers I could have used by cutting a section out of the top so I could see, yet most oil would stay contained.
Over the years, I've been checking around various forums and find quite a number of people have similiar oil pressure as I do. Yet many others have higher hot idle oil pressure.
But there's so many variables. Some cams require an idle of 1000 rpms or higher, so their idle oil pressure is higher. Some check the hot idle oil pressure before the engine is truly up to temp (it takes longer for the oil temp to rise than the water temp, so for those going by a water temp gauge, they could get higher readings). And viscosity and type of oil plays a small part. I can get a few more psi with 20W50 dino oil than with 15W50 Mobil 1.
However, I think my pressure is almost entirely due to bearing clearances. If a customer doesn't specify, I have no doubt many engines are rebuilt to stock specs, which have a wide range and can allow for very tight clearances.
Anyway, I thought it interesting enough to post my results. Might be of interest to others.
The 445ci is at .0015, restricted w/#80 jets, opening up filter to pump to 7/16th, lining up bearing holes, with the HV pump, and I get a hot idle (850rpm) of 45psi and about 60-70psi at cruise (2000-2400rpm). A max of 80psi (bypass) at high rpm. This is with a thinner 10w30 oil too. Quite the difference between the two! Good info.
