headlights messed up (brights work)
Old Jul 24, 2011 | 01:21 AM
1980302windsor's Avatar
1980302windsor
Hi all. I just did a project today and replaced transmission fluid and filter and refilled. Got ready to take it from the garage back out to its parking spot, and it was dark, so i turned the lights on....no headlights. All the other markers and lights work, just not the headlights. I tried the bright switch on the floor and they work! Why on earth would I have no dims but have brights. Left and right are both out! I checked fuses, connections, etc. Everything works. The only real trauma for the Truck was getting let down from the jack to the floor. It was a little rough, but nothing more than what a speedbump would do. Please help. Until It is fixed I guess i roll with brights only (sorry other cars)! Thanks guys.
Old Jul 24, 2011 | 01:22 AM
1980302windsor
I always forget to add specs. 1980 F150 V8 302 2wd automatic.
Old Jul 24, 2011 | 07:27 AM
fellro86's Avatar
fellro86
The dimmer switch itself is likely bad. Switch it out and you should be fine.
Old Jul 24, 2011 | 08:57 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Dimmer switch is a likely cause, but before dropping any money into parts, grab a test light and see if there is any power getting to the lights on low beam. It could be a wiring issue, or the rare fluke that both low beams burned out at the same time......
If they haven't worked at all in the time you've owned it, they could have burned out at different times, but the PO never bothered to replace them.....
Old Jul 24, 2011 | 12:08 PM
Shark Racer's Avatar
Shark Racer
What RW described happened to a friend of mine. Both of his low beams were worn out... amazing what some people don't notice.
Old Jul 24, 2011 | 12:40 PM
Galendor's Avatar
Galendor
Did you disconnect the battery cables during your transmission work? If so, check their connections. Poor connection at the battery can cause some wierd symptoms.
Old Jul 24, 2011 | 02:29 PM
1980302windsor
to answer a few questions
1. They are both brand new sylvania silverstar sealed beams. About 2-3 months old. I used dielectric grease on the connections when i installed them if that matters...
2. I didn't disconnect battery while working on transmission.
3. I will go voltmeter lights in lo beam when it stops raining.
I bet when i dropped it off the jack it finished something off that was on its way out. Maybe the dimmer switch as Rogue mentioned.
MichiganLarry
Jan 27, 2016 06:27 AM
ikswotug
Mar 21, 2013 12:00 PM
oldfart
13
May 31, 2009 12:21 AM
86stepsideF150
16
Jun 18, 2008 04:56 AM
xfordtech
Electrical Systems/Wiring
Aug 31, 2005 01:01 PM
