I am sorry about this but I have search on the web and here in the VIN Decoder in Articles/Spec and nothing. I am interested in what the 8th Character (D) is for the engine. The truck has a 351W. Also is the J code for Transmission the C6? Finally, is the 01 for axle have anything to do with it having a 9in? Thanks-Stephen
Thanks. Well I guess the 185k on the speedo doesn't reflect the mileage. I wonder where the engine came from and if it still has the original c4? We shall see. I am sure it has the original rear end because the 9 inch is 2.75 gears and NLS as indicated on the tag.
The 4.2L/255 was a V8 that *looked* like a 302, until you removed the intake or heads.
It used a valley pan intake gasket, like a 351M/400, and had a smaller bore. Very lousy engine, no power, and few lasted more than 50K miles.....
Well crap. In my ignorance this may not be the 351W that I had hoped. I have only had this truck a week. I did some searching and was told that you can identify a 351 by two easy ways: the intake measures 9 inches across and the valve cove has 6 bolts. I know the other way is that the top of the timing cover is not touching the bottom of the head but have not been able to get a good look. I wonder how I can tell that it is a 255? I can say it is a two barrel carb and the drive home last week proved that the engine was very week but I assumed it was low compression needing a rebuild as planned.
I wonder if anyone can tell from this picture. I am going to go out to take a closer picture of the intake. According to wikipid, it should have that open tunnel intake, whatever that looks like.
Maybe somebody else who knows these engines better will be able to identify it by your pictures, or will ask for closer pictures of < some component > .
I'll take a look through the parts catalog and see what I can find there....
Yep, dealer added A/C.
I believe the 255 has a unique block casting number, due to the smaller bore. I've heard that they cannot be bored out to 4.0" in order to turn it into a 302.
This isn't the tag I was originally looking for (which is smaller and stuck to the front of the pass side valve cover) but perhaps the Emissions label that you posted will do just as well - it says it's a 4.2L:
