Won't Start.
Old Jul 25, 2011 | 11:18 AM
  #46
PADoubleX's Avatar
PADoubleX
FICM Sync upon long cranking goes red.
Yes, fuel in upper bowl.
Reached out to a Ford Diesel mechanic I know.
His ideas:
1. Check to see if tach moves during cranking, if it does, it's not a cam sensor issue.
2. HPO leak.
My thoughts, if there's HPO issues, I don't think it would just not start. I think it would start cold, run like crap, and not start hot. And throw a Code somewhere. I think AE must be able to report HPO Pressure. I'll check that when I get home. Batteries are fully charged again so, let the fun being again.
I don't think the 58V FICM voltage is an issue. I'm not the only guy running it. What's the potential issue? It fried ALL the injectors? Not likely.
At work today, I'll report more when I get home tonight.
If I didn't say this earlier, I changed the fuel filters just for good measure.
And THANK YOU to everyone working through this with me.
Old Jul 25, 2011 | 02:47 PM
  #47
embry1123's Avatar
embry1123
Did you ever check the fan wire harness as suggested by blade35? Do you have a method (gauge) to check fuel pressure? Did you verify that CMP/CKP are in sync (this can be done with AE). With AE you can run an injector buzz test, run this test and listen carefully for each injector to buzz and pay attention to the sound of the buzz from each injector, they should all have the same tone. All 8 will buzz together and then it will run through them individually, 3 times it does this.
Old Jul 25, 2011 | 05:07 PM
  #48
npccpartsman's Avatar
npccpartsman
ICP is HPO pressure and by the numbers you posted at the start of this thread it's fine.
Old Jul 25, 2011 | 05:25 PM
  #49
embry1123's Avatar
embry1123
The fact that it went to over 1000 during cramming and then back to around 700+/- seemed a little odd, but I'm relatively new to this diesel game, so....
Old Jul 25, 2011 | 06:40 PM
  #50
BLADE35's Avatar
BLADE35
Originally Posted by npccpartsman
I had read that a LONG time ago and forgotten about it. Run the onboard diagnostic test and see what comes up again. You had something in RED IIRC.
Im with you on this one Tim His FICM sync went red 1 ficm IIRC
Does your AE have a 1 FICM Sync It goes green on a known good FICM
Old Jul 25, 2011 | 09:53 PM
  #51
PADoubleX's Avatar
PADoubleX
OK here's what I know so far.
ICP 1300 PSI
FICM 57.2V
Cam Sensor 0 Green
Battery 12V+
My brother's stepson is a diesel mechanic, he says I should see the tach move when cranking, says if it doesn't cam sensor is no good. Can someone crank their diesel and see if the tach moves.
FICM Sync went red with extended cranking.
FWIW Will all this cranking, no smell of diesel at exhaust.
How do i check crank sensor in AE, I didn't see that in the sensor list.
Old Jul 25, 2011 | 10:03 PM
  #52
dchamberlain's Avatar
dchamberlain
My tach doesn't move until a second or so after it starts. I don't think that is a good indicator of either cam or crank sensor operation.
I don't think their are PID's for either the cam or crank operation, other than sync and FICM sync. I'd have to hook up and look them over though, to see for sure.
I might be able to do that in the morning, but I have to get some stuff done and get to town to get ball joints done, so I might not be able to do anything until tomorrow evening.
Old Jul 25, 2011 | 10:18 PM
  #53
PADoubleX's Avatar
PADoubleX
Thanks for checking.
Starting to wonder why I don't have the smell of diesel at exhaust after all this cranking.
Could the ICP be reading false? It's an 05 so the icp is kinda easy to get to. Think it worthwhile to put a mechanical gauge in the ICP port?
Where would I test fuel pressure?
I did check the fan wire harness. It's good.
I did the buzz test, it passed in AE. Not really sure what I'm listening for, but I did hear it buzz.
Old Jul 26, 2011 | 05:33 AM
  #54
embry1123's Avatar
embry1123
There is an Allen head bolt at the bottom left on the front side of the upper fuel bowl assy, this is the test port. Crank and cam sensors are only checked by watching CMP/CKP sync on AE. On the buzz test you are listening for all individual injectors to buzz with the same intensity and tone. A bad injectors will buzz much more quietly or not at all. 1 injector bad = run like crap, 2 bad and engine will likely not start. Your ICP pressure seems fine. Do you hear the fuel pump running?
Old Jul 26, 2011 | 05:34 AM
  #55
npccpartsman
Fuel pressure test port thread in the top picture fitting size is M12x1.5. Most gauges are 1/8" NPT. Page 30: Fuel Supply System
I'm going to have some more time with AE this morning so I'll see if I can figure out something else on the FICM sync readings that AE gives. There's a lot of stuff I still can't find that I should have and hopefully I'll know more when my tutor calls this morning--LOL.
Old Jul 26, 2011 | 05:48 AM
  #56
embry1123's Avatar
embry1123
The AE tutorial isn't much is it? Perhaps there is a market for some vehicle specific tutorial videos? Like the ford tech time videos? LOL
talk to ya later this a.m.
Old Jul 26, 2011 | 11:33 AM
  #57
PADoubleX's Avatar
PADoubleX
YES!
From embry1123
"Did you verify that CMP/CKP are in sync ?" They are not.
Just got DTC P2617 Crankshaft Position Sensor Circuit Open
Never been so happy to get a code. At least I have a direction to head now.
Old Jul 26, 2011 | 11:53 AM
  #58
npccpartsman
YES!
From embry1123
Just remember that you can get that code from a stall event or crank no start, but at least it's somewhere to start. Check the plug-in for oil contamination and remember that the harness is considered to be non-repairable because it's shielded.
FYI--I had FICM sync and CMP/CKP sync on the live grid with the motor running and the CMP/CKP sync goes on and off all the time however they DO have to be in sync for the motor to start. The FICM sync reads 1 when it's all good. The gauge being in the red % range is because of the way it's scaled not because of a fault.
Old Jul 26, 2011 | 12:04 PM
  #59
dchamberlain
I recall Cheezit saying once that you need sync for the motor to start, but after that it isn't necessary.
As I see it, the crank position sensor is what the engine needs for timing. It's a 60 tooth hall effect sensor with two teeth missing. Since the cam goes around once for every two crank revolutions, the cam sensor is used to let the PCM know which TDC is between which of two possible strokes. Once it knows that, it remembers it and doesn't need the cam sensor anymore.
Old Jul 26, 2011 | 01:04 PM
  #60
PADoubleX's Avatar
PADoubleX
Waiting on the CPS, in at 3:30 today, I'll install tonight. $52 gamble.
I had FICM sync issues after extended crank. Today I had CMP/CPK out of sync issues, the P2617 DTC.
We'll see what happens tonight.
