Won't Start.
Old Jul 23, 2011 | 03:51 PM
PADoubleX's Avatar
PADoubleX
FICM shows 0 at key on.
FICM shows 1 on crank
0 is green, 1 is Red. 1 must be fault.
So what exactly does this mean?
Old Jul 23, 2011 | 05:12 PM
BLADE35's Avatar
BLADE35
not shure about the AE
But my SGII shows 1 for FICM sync means good I would think AE would be the same
Have you checked for fuel in upper fuel bowl??
fuel filters??
ICP looked good to me as well
also check the wiring at the fan shroud for the fan clutch
heres what mine looked like time would have killed it
Old Jul 23, 2011 | 05:58 PM
PADoubleX's Avatar
PADoubleX
so, I'm getting P0611 FICM
I originally thought this was because the FICM I'm using is from SWAMPS Diesel and has higher than stock voltage. I see main power as 52V Logic 12v Vehicle 12V. This FICM originally was 58V something happened. Guess I'll wait till Monday to talk to Swamps.
Ideas?
FML.
Old Jul 23, 2011 | 06:04 PM
BLADE35's Avatar
BLADE35
You might be on to something even though 52v should be enough voltage
what FICM voltage do you get during your cranking
do you hear the injectors buzz when the key is cycled to on
Old Jul 23, 2011 | 06:25 PM
PADoubleX's Avatar
PADoubleX
Disconnected batteries to reset PCM. Still no start.
52V constant when cranking. I think something is up with the FICM, all the symptoms. Just hard to believe since it's new. Like I said earlier it's been 107 here, it is mounted on the engine so maybe the heat got to it? Guessing.
Yes, Injectors buzz.
BTW. A shot of ether it tried to start, my thought there is ether doesn't take much to ignite.
Sent an email off to swamps just in the off chance they're like a lot of us and work weekends.
Old Jul 23, 2011 | 06:32 PM
npccpartsman's Avatar
npccpartsman
I've heard the AE only reads FICM voltage to 52 but I'm wondering if you reconfigure the gauge range to something like 60 will it read the full voltage.
That being said--IIRC in the AE tutorial if something comes up in RED it's a fault which to me would say that it's not in sync.
There is a FICM fuse and relay under the hood close to the brake booster in a small black box. You might check those also.
Old Jul 23, 2011 | 06:37 PM
npccpartsman
I would definitely be calling swamps although I'm not sure anything they do affects a P0611 code, which is a RAM/ROM fault or loss of FICM power.
Do you get any smoke while cranking?
PADoubleX's Avatar
PADoubleX
Hey thank you. Both great ideas, headed to do that right now. I forgot about the fuse under the hood. You don't know anyway to check the relay do you?
Old Jul 23, 2011 | 06:46 PM
npccpartsman
Well.....if you're getting FICM main power and FICM logic power then all you have left is FICM control power. Or maybe this FICM test will help.
File Type: pdf
Old Jul 23, 2011 | 07:04 PM
PADoubleX's Avatar
PADoubleX
Is the FICM Power Relay the one in the Fuse panel?
Do you have the
Wiring Diagrams Cell 149 Component Testing
That procedure is awesome, may I ask where you get that?
Old Jul 23, 2011 | 07:09 PM
npccpartsman
Do you have the
No. The FICM relay is the one next to the 10A fuse in the black box under the hood. Dchamberlain is online now. If you shoot him a PM he possibly has that test.
Old Jul 23, 2011 | 07:26 PM
npccpartsman
The Sync/no sync is in the 6.0 tech folder under this heading: http://www.fordtechservice.dealercon...FICM_Guide.pdf
Old Jul 23, 2011 | 07:47 PM
  #28
dchamberlain's Avatar
dchamberlain
This is the wiring diagram for the FICM power relay, if it helps.
I believe the power relay is in a relay box that has a relay and a fuse in it. I say I believe because the diagram of Aux Relay Box 5 in my book doesn't look quite like the relay box in my truck. You might check that fuse, too.
Old Jul 23, 2011 | 07:48 PM
  #29
dchamberlain
Oh, PS. The fuse numbers you might see in any of my diagrams apply to a 2002-2004. They changed before and after that.
Old Jul 23, 2011 | 08:13 PM
  #30
PADoubleX's Avatar
PADoubleX
Thanks David.
Replacing fuel filters now, just to play it safe. I'm kinda stumped.
