Won't Start.
Only code I'm pulling if P0611 - FICM RAM/ROM fault..
Waiting to hear from swamps on Monday. I think even though the FICM has 57.2V, something in it has failed. It's about the only thing that makes sense at this point.
Comments?
have someone cycle the key while you listen for the buzz
injectors will still buzz once the key is cycled but
the engine will not start. There will be no other
symptoms related to the no start condition.
I have 12V FICM Logic 57.2V FICM Main 12V FICM (the other one I can't remember)
I guess what I'm trying to prove is just becuase the FICM has power it doesn't mean it "works" Hence P0611
It doesn't start, it throws P0611, sure sounds like a FICM issue.
For my sake, I hope it is.
Just heard from Dave at Swamps. Very impressed, he emailed me twice on a Sunday.
Dave says, "P0611 is voltage out of range, in this case high"
If you have a way to monitor INJECTION control pressure (High pressure oil) Then I would like to see what the ICP_Actual psi and compare that to ICP_Desired.
The desired is what the ECM is requesting, and the actual is what is actually being reported by the ICP sensor to the ECM"
I think I previously posted my ICPs. Going to look for them now.
<TABLE style="WIDTH: 110pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=147 border=0><COLGROUP><COL style="WIDTH: 62pt; mso-width-source: userset; mso-width-alt: 3035" width=83><COL style="WIDTH: 48pt" width=64><TBODY><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; WIDTH: 62pt; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" width=83 height=20> 01:15:44.010</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; WIDTH: 48pt; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right width=64>112.17</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:44.385</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>1061.09</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:44.806</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>1188.55</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:45.211</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>1016.9</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:45.601</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>969.31</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:46.007</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>946.08</TD></TR><TR style="HEIGHT: 15pt" height=20><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; HEIGHT: 15pt; BACKGROUND-COLOR: transparent" height=20> 01:15:46.397</TD><TD style="BORDER-RIGHT: #c0c0c0; BORDER-TOP: #c0c0c0; BORDER-LEFT: #c0c0c0; BORDER-BOTTOM: #c0c0c0; BACKGROUND-COLOR: transparent" align=right>759.13</TD></TR></TBODY></TABLE>
P0611 Fuel Injector Control Module Performance D* d
I think your HPO system is ok
It was building enough pressure to start anyway
I saw the P0611 as Ram/Rom fault. Noted nothing to do with High voltage.
Now what?
It sure seems like a dead ficm. I'm guessing the programming got corrupted. He's the FICm expert so I'll run down the ICP issue with him.
Anyone running Swamps Hot FICM or a DIY 58V FICM? - Power Hungry Performance Forum
Awesome, so truck isn't throwing any codes, it just doesn't start. This really isn't fun anymore.
this what scared me about the power upgrade codes &
and the fact the injectors are now getting 10volts than what it was originaly designed for
well for some reason I always had it in my mind that if they buzzed the injector drivers was good in the ficm
Ok so theres more to it than that
