97 psd icp
Old Jul 28, 2011 | 09:14 PM
  #31
Action4478's Avatar
Action4478
Originally Posted by brad7.3
Yes, 650psi at idle, under 1500psi wot
That would be oil pressure ...
There is a schraeder valve on the FPR to test the fuel pressure ...Name:  Fuel heater connection.jpg
Old Jul 29, 2011 | 05:35 AM
  #32
brad7.3's Avatar
brad7.3
Oops, I read fuel, but saw oil. No, haven't checked fuel pressure, what kind of fuel pressure should it have?
Old Jul 29, 2011 | 06:11 AM
  #33
427 fordman's Avatar
427 fordman
It should have about 40-60lbs at idle.
Old Jul 29, 2011 | 09:21 AM
  #34
brad7.3's Avatar
brad7.3
Ok, I'll check this afternoon. But, Would the fuel pressure have anything to do with the low oil pressure though?
Old Jul 29, 2011 | 01:40 PM
  #35
brad7.3's Avatar
brad7.3
Ok, checked fuel pressure, cold engine startup, at idle 80psi, and oil pressure @1000psi.
Old Jul 29, 2011 | 06:29 PM
  #36
brad7.3's Avatar
brad7.3
Ok, checked fuel pressure, cold engine startup, at idle 80psi, and oil pressure @1000psi. Would the fuel pressure affect the oil pressure?
Old Jul 29, 2011 | 06:39 PM
  #37
Action4478's Avatar
Action4478
Low FP can set the code , PCM is calling for ICP at 1000, seems to high to me ...THe IPR may not be responding properly ...
Old Jul 29, 2011 | 09:51 PM
  #38
brad7.3's Avatar
brad7.3
Should I replace the ipr valve then?
Old Jul 29, 2011 | 10:21 PM
  #39
oldbird1965's Avatar
oldbird1965
You might be able to give it a good cleaning. I didn't have any luck with mine and finally just bought a new one.
Old Jul 30, 2011 | 08:09 AM
  #40
brad7.3's Avatar
brad7.3
I'll just buy a new ipr, and try it.
Old Jul 30, 2011 | 08:19 AM
  #41
bad12jr's Avatar
bad12jr
They are almost 300 dollars. That a lot of money to just try
Old Jul 30, 2011 | 08:59 AM
  #42
oldbird1965
I've seen them on Ebay for cheaper. I got mine from Joey at Terminator for $200.
Old Jul 30, 2011 | 09:31 AM
  #43
Action4478's Avatar
Action4478
Unless you have the extra cash to use on an IPR test , I would take it out & verify the O ring on the small end is good & give it the shake test. (it should rattle). We are also assuming the oil is full( not in need of a change ) & diesel rated ..
I'm not a fan of cleaning the IPR at no start , but it may help in this case ....
If you buy one ,they are fairly cheap on E bay , if that is not the problem , it doesn't hurt to have a spare ...
Old Jul 30, 2011 | 10:08 AM
  #44
brad7.3's Avatar
brad7.3
I'll probably just get one and try it, I need to get thing running better. I'm kinda getting tired of screwing with this thing, if it wasn't in such good shape and long paid off, I'd get rid of it! But who wants a truck payment?
Old Jul 30, 2011 | 06:23 PM
  #45
brad7.3's Avatar
brad7.3
How would I go about changing the ipr once I have a new one? I've found several of these on eBay, from 65$ - 200$+. What one should I get?
