97 psd icp
Old Jul 26, 2011 | 05:27 PM
427 fordman's Avatar
427 fordman
You can plumb it in on the head, just remove a plug. Should be around 750 at idle, 550 or so cranking I believe, be nice to get some of the guys with a little more experience to tell you the pressures it should show for sure as rpm's increase.
If Chris pops back in this thread as he already has, he'd know for sure.
Old Jul 26, 2011 | 05:51 PM
427 fordman
WOT should be about 3000, that should get you started. Should just be a climb from the 750 up to the 3000. No set pressure really with a certain rpm. I did a little searching.
Leave the chip out if/when you test it.
Old Jul 26, 2011 | 07:46 PM
oldbird1965's Avatar
oldbird1965
I'm around 600psi at idle and when just talking off maybe 1,000 or a little more. Put it in one of the plugs on the head to read the pressures.
Old Jul 26, 2011 | 07:57 PM
brad7.3's Avatar
brad7.3
Ok great, that will get me started. It may be a day or so before I'm able to check it, but I'll post my findings as soon as I get them! Thanks fellas!
Old Jul 26, 2011 | 08:04 PM
oldbird1965
I did a really crude test years ago. I got a gauge, some hose and hung the gauge out the hood at the crowe to read it. I tied the hood down and went for a ride. Boys and girls, don't try this at home, LOL
Old Jul 27, 2011 | 02:16 PM
427 fordman
I may be off on the 750, 600 sounds about right. Guess I should look at my scan gauge and maybe pay attention at the same time. It's even set on the icp pressure
Come on Glenn, that sounds like the perfect gauge setup!!!
Old Jul 27, 2011 | 02:43 PM
Action4478's Avatar
Action4478
There are a few things that can set 1211..
I might start with verifying fuel pressure . (cheap test). Are you due for an oil change ? Is the C Case full ?
You may want to un plug the ICP sensor & see how it runs. It will still code but may run better ...
From the manual:
DTC P1211 indicates that injection control pressure was above or below commanded desired pressure during self test mode.
Possible causes:
incorrect oil or viscosity
poor oil quality
gel fuel/no fuel
low fuel pressure
damaged IPR valve
high-pressure oil system leak
damaged high-pressure oil pump
damaged PCM
Verify correct oil quality/viscosity and correct fuel grade are being used for the temperature conditions.
Old Jul 27, 2011 | 05:41 PM
brad7.3's Avatar
brad7.3
got a gauge to test fuel pressure, I'm going to try to do it in a little while, if it's not raining by then, I'll let you know what I find for pressure.
Old Jul 27, 2011 | 09:50 PM
oldbird1965
Perfect setup huh Darin. Reminded me of, can't remember for sure, was it the GTO that had a gauge on the hood in front of the driver? The thing was though after I got my reading I just set the gauge on the motor and the liquid filled gauge must not have liked the heat of the motor and it started to leak.
Old Jul 28, 2011 | 05:21 PM
brad7.3's Avatar
brad7.3
Ok, gauge connected. @ 650psi at idle. Took it for a ride, it still accelerates like it sucked a chevy truck into the air intake! The highest reading I got was barely 1500psi! Any Ideas?
Old Jul 28, 2011 | 06:50 PM
427 fordman
Have you unplugged the icp and tried it like Rick suggested?
Old Jul 28, 2011 | 07:34 PM
brad7.3's Avatar
brad7.3
No, but I'll do so in just a few minutes.
Old Jul 28, 2011 | 07:43 PM
  #28
brad7.3's Avatar
brad7.3
Unplugged icp, no difference.
Old Jul 28, 2011 | 07:58 PM
  #29
Action4478's Avatar
Action4478
Did you test the fuel pressure ?..
Old Jul 28, 2011 | 09:05 PM
  #30
brad7.3's Avatar
brad7.3
Yes, 650psi at idle, under 1500psi wot
