its here its here!!
Old Jul 29, 2011 | 04:56 PM
  #31
fordman75's Avatar
fordman75
Originally Posted by F-250 restorer
I agree that the Clifford stuff is over-priced. The cam grind is a bit special that I haven't seen anywhere else. My Isky 256 cam with 1.7 rockers about equaled his cam, but with a tad more duration. Ever since I read about the guy on Fordsix whose new Cliff cam kept shredding his bearings in no time, I have been VERY skeptical of Cliff's products. It turned out the journals had not been polished and were shredding the bearings like a cheese grater. Also, their return policy is poor; So I have read. I also found it interesting that although they call it a 264 duration cam, @ .050" the Comp 260 actually has more duration, by ten degrees!
One note about the Cliff headers: He is the only one I have seen with 1 5/8" tubes.
I think $400 for an intake is ridiculous! But if they are the only ones making the multi-carb intakes then I guess they can set their own prices.
I won't buy anything internal for the engine from them. And you can contact other cam companies and have a cam ground to whatever spec you want, if they don't offer what you want.
I bought a pair of headers from them quite a few years ago. I was not impressed with the quality or how they fit.
For my stock engine I'm going with Hedman headers. I've had good luck with them on 240/300. I'm just really hoping their 89300's fit my 78 F150 4x4. They say for 2wd but I can't see why they wouldn't work on the 4x4's. There's no cross member for them to hit except the transmission X-member.
When I get my high compression engine done I'm going to build my own large tube headers.
Old Jul 29, 2011 | 05:03 PM
  #32
1bad67sbf's Avatar
1bad67sbf
the header will send one pipe into the edit: crossmember and transfer case: but any custom exhaust shop can fix it easy
Old Jul 29, 2011 | 05:12 PM
  #33
fordman75's Avatar
fordman75
Thanks for the info. That won't be a problem then.
I'm building my own system. I don't trust anyone else to work on my vehicles. I'm just going to buy some straight pipes and some mandrel bent U-bends. Oh yea and I can't forget about the Hooker Aero-Chamber mufflers.
Old Jul 29, 2011 | 05:16 PM
  #34
1bad67sbf's Avatar
1bad67sbf
this may help but the pic quality sucks, sorry
Old Jul 29, 2011 | 05:35 PM
  #35
fordman75's Avatar
fordman75
I've got a NP435/NP205 in my truck. So the front collector will be fine.
That rear collector will take some creative pipe work to clear the 78 trans X-member. But it should be doable.
Old Jul 31, 2011 | 09:36 PM
  #36
dyingtolive's Avatar
dyingtolive
Ooh.. I wonder if that'd be a problem with a ZF 5 speed transmission..
Old Jul 31, 2011 | 11:40 PM
  #37
fordman75's Avatar
fordman75
Why would it? The ZF isn't much wider then a NP435 or a T-18. Now if you had a C6 auto it might be just a hair tighter!
fordboy300
Feb 27, 2017 07:38 PM
fordboy300
Feb 17, 2016 07:10 PM
fordboy300
23
Nov 20, 2015 03:49 PM
fordboy300
Oct 7, 2015 07:39 PM
tdogmason
Jul 14, 2012 06:08 PM
