Sponsored by: Real Truck
Brakes vs climate control
Old Jul 21, 2011 | 11:39 PM
Brad J's Avatar
Brad J
I have a 2005 F350 lariat automatic diesel with climate control. Randomly, yet regularly, when i press the brake the fan motor stops for a second and then restarts. It will do it several times a day and I cant reproduce it on command. It always just blips the fan for a second and then it resumes.
Any ideas what the cause may be? I'm not convinced inertia or movement has a direct correlation to it. I never notice it when cruising.
Thanks,
Old Jul 22, 2011 | 09:52 AM
Kajtek1's Avatar
Kajtek1
I am having bad connection on my blower motor plug under the hood and have to push it on occasions. That is where I would start checking.
Old Jul 22, 2011 | 11:38 AM
44dwarf's Avatar
44dwarf
Are you sure its the fan and not the door inside the A/C box swinging?
You might have a bad check valve in the heater contorler vacuum tank. brake use vacuum thus might steal away from the a/c tank.
44
Old Jul 22, 2011 | 11:44 AM
dchamberlain's Avatar
dchamberlain
Brakes on a 2006 diesel don't use vacuum.
Is just the fan stopping, or is the entire climate control head unit going dark?
Old Jul 24, 2011 | 11:51 PM
Brad J's Avatar
Brad J
It is the fan stopping only, climate control stays on. I did jiggle the harnesses and was able to identify a bad connection in the vicinity of the fan. Stopped doing it before I could figure out where though......
jprix
Dec 3, 2013 03:08 PM
Soundman7
Jun 14, 2013 10:24 AM
2011f150js
2009 - 2014 F150
13
Mar 29, 2013 08:36 AM
PeeWeeRacer
Jul 31, 2008 07:06 PM
"Eddie_B_Bauer"
Mar 22, 2004 09:43 AM
