Quick master cylinder question
Old Jul 20, 2011 | 10:10 PM
swooshcmk's Avatar
swooshcmk
I just want to verify...
I'm upgrading the master cylinder on my truck from the cast iron style to the aluminum housing with plastic reservoir. Can someone with that style MC verify something for me?
Does the front port on the MC (front of truck) go to the Calipers and the rear port by the cab to the rear wheels? Or vice-versa?
Can't tell just by looking at it
Thanks!
Old Jul 20, 2011 | 11:30 PM
swooshcmk's Avatar
swooshcmk
anyone? lol
Old Jul 20, 2011 | 11:51 PM
Phy's Avatar
Phy
Yes, that's correct. Front port to the front wheels, rear port to the rear wheels. It should have a proportioning valve screwed into the rear port, and your rear brake line screws into the proportioning valve.
Old Jul 20, 2011 | 11:54 PM
swooshcmk's Avatar
swooshcmk
Thanks, that's all I needed! Wanted to double check I had the right lines going to the right place!
Old Jul 21, 2011 | 02:13 AM
ford390gashog's Avatar
ford390gashog
MAKE SURE you have the correct push rod installed or you will have issues!!!
jazzyndon52
Jan 9, 2015 04:45 PM
1Tonn
18
May 23, 2011 09:23 AM
palehorse13
May 29, 2010 03:25 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Nov 14, 2006 06:23 PM
bryan_johnson
Mar 6, 2005 07:49 PM
