Now what happened?
Old Jul 19, 2011 | 03:02 PM
Fatcatpaddy's Avatar
Fatcatpaddy
Now what happened?
I installed the new Motorcraft glowplugs and for the 2 starts it worked perfectly with the wts light but today (third time starting) wts light instantly goes out and I hear clickclick, clickclick.,etc. but then I look at the volt gauge and from what I see no amps are being drawn from the batteries when their clicking, then I have to turn it over for a good 15secs. Not only that but yesterday I was driving to discover that the brake light comes on when I come to a stop the brake pedal has always been a little spongy, I took the truck to a brake shop they worked on it, replaced master cylinder and still the spongy brakes are there. They could not find a solution
Anyone have a solution to either of the problems
Old Jul 19, 2011 | 03:37 PM
ah1988's Avatar
ah1988
The click click click is the controller, idk how there is no power draw on the battaries when the controller is clicking, i am pretty sure it uses power
from the battaries to run. You may have a bad controller or relay, i would test the glow plugs to see if any of them were lemons for the heck of it .
Old Jul 19, 2011 | 03:45 PM
Fatcatpaddy
Ok will do, I know for a fact that I see the batteries getting drawn from when its working but now I dont see a battery draw
Old Jul 19, 2011 | 05:04 PM
joe f350's Avatar
joe f350
frist thing u did it wrong was taking it to a shop second thing we need info on ur truck it a 7.3 right i would check the gp contorler andd the realys
Old Jul 19, 2011 | 05:38 PM
tjc transport's Avatar
tjc transport
i ain't rite
check all the connections on the controller and relay, and also check to make sure the grounds for the controller and relay are good and clean.
Old Jul 19, 2011 | 06:03 PM
Fatcatpaddy
I'll take a look at it when it cools down, normally I have our company mechanic work on it in the drive way, I'm not going to that brake shop again lol.
What info would you like?
Has 120k miles runs strong (once it fires)
Old Jul 19, 2011 | 07:16 PM
ADTMan's Avatar
ADTMan
Specs, year 3/4 or 1 ton 2wd or 4 wd....Factory turbo or no, aftermarket turbo or no turbo at all.
Old Jul 19, 2011 | 07:33 PM
joe f350's Avatar
joe f350
these trucks have two diffrent glow plug systems 87 and up and one sytle the others are 86 and below
Old Jul 19, 2011 | 07:50 PM
Fatcatpaddy
Oh ok, 1992 4wd dually f-350 1ton? Non turbo new interstate batteries
Old Jul 20, 2011 | 12:48 PM
Fatcatpaddy
I just found my glow glug relay smoking this morning when I went to start the truck:P
Im replacing it tomorrow
Old Jul 20, 2011 | 09:59 PM
84-6.9L's Avatar
84-6.9L
ask for the 86 ford glow plug relay so they don't try to sell you the whole controller for over 130bucks. Asking for the 86 gets you the relay and i sounds like thats all you need
Old Jul 20, 2011 | 11:26 PM
Fatcatpaddy
Ok will do, I hope thats the end of this glow plug (mess)
43tutor2
Jan 8, 2014 07:25 PM
clintusaf
Jul 8, 2012 02:36 AM
krane operator
1983 - 2012 Ranger & B-Series
Sep 26, 2009 05:59 PM
tdanco
Oct 6, 2003 04:03 PM
jda
Feb 25, 2002 06:14 PM
