Engine Block Rust Question
Old Jul 18, 2011 | 06:10 PM
Trojan8975's Avatar
Trojan8975
Surface rust covers my entire lower engine block on my 92 Ford Nite; Does any one know the cost to drop the engine, remove the rust, and repaint/prime it?
Old Jul 19, 2011 | 03:51 AM
BucksTrucks's Avatar
BucksTrucks
I wouldnt worry about the rust on the block its self. It would take 100 years for that block to rust through if it was sitting at the bottom of the great salt lake. I would be worried about the oil pan though. Those are thing steel and will rust through. Your best bet is to remove the upper intake, exhaust system, and unbolt the motor mounts. Jack the engine up, pull the oil pan bolts reach up under that thing and unbolt the oil pump. Pull the pump and pan out. Then PPP the pan, buy a new oil pump and re assemble.
Old Aug 12, 2011 | 03:00 PM
F350Kid238's Avatar
F350Kid238
not necessarily my block was like 1/8 thick and got a hole in it and it was a 96 take a look at my photos. see if its as bad
sanders92
1978 - 1996 Big Bronco
Sep 17, 2012 04:34 AM
cheesecake28
Jul 14, 2011 07:55 AM
SD F350 99
Oct 2, 2010 09:03 AM
wadar1969
Jun 25, 2010 10:01 PM
SD F350 99
Oct 14, 2009 07:39 PM
