Rust Prevention
Old Jun 25, 2010 | 08:58 PM
wadar1969's Avatar
wadar1969
Rust Prevention
I am having my 79 F-100 sanblasted monday and would like to put a good rust preventer primer on it right after. I want a system that is simple and can be blocked and painted over. Any suggestions will be greatly appreciated.
Old Jun 25, 2010 | 09:03 PM
Diesel_Brad's Avatar
Diesel_Brad
As long as it is sandblasted correctly ANY self etching primer will do fine
Old Jun 25, 2010 | 09:13 PM
wadar1969's Avatar
wadar1969
OK thanks, The guy said hes using shells to blast it with. I only have a couple small areas that has rust through the metal, the rest is just surface rust ( unless the blasting exposes something I cant see now) I want to have it treated quickly then take it to the painter and let him do his thang. Can I put rust preventer over an etching primer or do i need to put it on first. Im looking at POR-15, products from Eastwood and Rust Bullet
Old Jun 25, 2010 | 10:01 PM
benmoderow's Avatar
benmoderow
I did por15 on mine on the problem areas, where they typically rust out. Then epoxy primer and then 2k high build primer.
speakerfritz
Feb 24, 2014 04:02 PM
twom7
32
Oct 5, 2012 02:57 PM
78sharpshooter
28
Sep 7, 2009 10:47 PM
Lesspaul
General Automotive Discussion
20
Nov 5, 2004 05:28 PM
panteramatt
Mar 3, 2004 10:57 AM
