Sponsored by: Real Truck
05 conversion issue
Old Jul 18, 2011 | 12:14 AM
xmontex4's Avatar
xmontex4
05 conversion issue
I recently installed the 05 header panel lights and grille and my hood shuts extremely close to my grille and i have to slam it hard to shut it. im not sure if i put the panel on wrong or not, does anyone have any ideas that might help?
Old Jul 18, 2011 | 12:53 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Double check your bump stops.
Old Jul 18, 2011 | 11:53 AM
xmontex4's Avatar
xmontex4
Their rusted to the spot they were in in the factory i cant move them without breaking them ill probably have to get new ones, is there anything else i could try in the mean time? the grille itself just looks really high unless my hood is just closing low, im not sure if its related to the panel or not though ive got the 04 bumper on it as well not the 05
Old Jul 18, 2011 | 12:50 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I know that if you buy an 05+ grille, and keep the 99-04 bumper, then you have to trim a little off of the bottom of the grille. Did you do that?
Old Jul 18, 2011 | 01:15 PM
xmontex4's Avatar
xmontex4
yeah i bought the pre-cut grille off ebay and relocated the clips on the bottom to line up with the 05 header panel, are the hood bumpers the only option? the panel is simple it can only be mounted one way correct? or can it be adjusted up and down or tilted slightly? (sorry if it sounds like a stupid question just trying to evaluate all my options)
Old Jul 28, 2011 | 12:02 AM
xmontex4's Avatar
xmontex4
Issue discovered!
I discovered the issue this past weekend when i was looking over the truck in more detail. I realized that my plow frame for some reason comes right up under the header panel which on the 05 panel is a solid bar but on the 04 panel the spots for the clips are set down from the main part. This was causing the panel to sit slightly up and have a slight bend upward which was causing my grille to sit extremely close to my hood. In order to fix this I had to remove the 05 panel and install my original panel until the plow is removed this coming fall and my clearance issue will be resolved.
Old Jul 28, 2011 | 12:25 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I'm gonna rep you for 1) asking a good question, 2) responding to an answer, 3) solving your own problem, but mainly 4) telling us the solution you found.
Good job man
Old Jul 28, 2011 | 10:12 PM
xmontex4's Avatar
xmontex4
Thanks! anything i can do to help someone in the future with the same issue.
Old Jul 28, 2011 | 10:19 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Youre not the first one to have issues because of plows. You didnt say if you had the plow package, but I know lots of people have small problems with stuff like that because a lot of little things change with a plow package but they arent well documented on here because plow packages arent common, and especially not common outside of a fleet.
Kudos to you!
Old Jul 31, 2011 | 09:12 AM
xmontex4's Avatar
xmontex4
It does have the plow package, i though it was just more heavy duty suspension etc. i haven't really looked into it much because the plow is going to be taken off hopefully this fall.
Thanks! :-)
Old Aug 22, 2011 | 08:20 AM
xmontex4's Avatar
xmontex4
Took me a few weeks with work and everything but i took my old stock panel and trimmed it to fit the new 2005 headlights and I reinstalled it. Now my grille clears my hood no problem all issues have been resolved.
Heres the 2005 Header panel installed.
This is with the original panel cut out to fit the new headlights.
Old Aug 22, 2011 | 10:55 AM
Eatonpcat's Avatar
Eatonpcat
Thanks! :-)
Most people put their plows on in the fall!!!
Old Aug 22, 2011 | 11:46 AM
xmontex4's Avatar
xmontex4
lol I know, my father was the one who used it to plow where im still in school and he doesnt want to do it anymore and i dont heave time etc. lol
hasteranger
Feb 22, 2015 08:33 AM
65f100_352
Jul 23, 2013 09:28 AM
flatbeder
Jul 27, 2012 12:33 PM
xmontex4
Apr 20, 2011 06:49 AM
xmontex4
Jan 7, 2011 05:04 AM
