fan clutch
Old Jul 17, 2011 | 09:39 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by Dodge/Cummins
I wish you didn't live thousands of miles away, I'd borrow that sucker! LOL!
You can use a air hammer and a chisel on the flats of the fan clutch nut.
Old Jul 17, 2011 | 09:50 PM
Dodge/Cummins's Avatar
Dodge/Cummins
I've never had a problem with a fan clutch nut, I've always made my own wrench with a fairly long handle and whacked it with a hammer but I can think of all kinds of uses for that tool.
Old Jul 18, 2011 | 12:06 AM
starmilt's Avatar
starmilt
Hammer and chisel, I guess will work, if you are in a bind and changing the water pump and fan clutch anyway.. Keep in mind though that you are beating on the seal and bearing for the pump.
Old Jul 18, 2011 | 12:12 AM
84-6.9L's Avatar
84-6.9L
borrow the tool from the auto parts store it also has a wide wrench that slides over the 4 pulley bolts so you get a good grip on the pump.
Old Jul 18, 2011 | 12:24 AM
Jayme Duty's Avatar
Jayme Duty
New Question. I got everything apart and back together after i rented the right tool. filled the radiator and took for a drive to get to temp. at first start the belt was whining, i new that i spilt some coolant and figured that was the belt whining. Well 8 hours of 90 degree heat the belt should be dry. A friend came by and said that was a pulley making the noise. There was no noise when i took off the belt off to change the water pump. i spun every pulley when the belt was off and everything looked good. Is there another way to determine bad pulleys
Old Jul 18, 2011 | 12:47 AM
starmilt's Avatar
starmilt
You can spray wd 40 on the bearings for the idler , if the noise goes away , you know you have a bad bearing. Any chance your water pump bolts are rubbing the timing gear.
Old Jul 18, 2011 | 08:54 AM
Jayme Duty's Avatar
Jayme Duty
I sure hope not. I guess i could loosen them one at a time and see if that helps
brandon.edwards
Apr 13, 2014 09:30 PM
desertt5
Mar 31, 2011 09:32 PM
mudmagnet
Jan 10, 2010 08:05 PM
995.4SD
Jan 12, 2009 08:33 AM
4x4Subaru
Apr 23, 2004 04:03 AM
