I got off the sensors.
Can not test the sensor that is working / not working?
What should the new sensors cheaply?
Rear radars switched off as soon as I put the R-gear position.
Can I test the sensors individually, in any way?
A bit confused on your problem. Are you saying that you don't know which sensor is not working...or do they ALL not work? If they are all not working, have someone make sure your Reverse backup lights are coming on when you are in reverse. If not, then your DTR Sensor likely needs to be replaced (about $75 new, or $20 used on ebay). It is located on the outside driver's side of the transmission. Very simple and fast to replace yourself, but make sure that's the problem first.
Don't forget to check the owners manual to double-check any associated fuses. It could be something as simple as that.
