started smoking BLACK
Old Jul 15, 2011 | 11:41 AM
wuttrd's Avatar
wuttrd
on the drive home yesterday noticed when i would take from a stop i am getting quite a bit of smoke. i am only in 60E not towing not racing just normal driving. never noticed that much smoke,even in 120R. what could be the cause????
Old Jul 15, 2011 | 12:04 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Not sure.
Have you tried the stock setting to see what that's like?
Could possibly have an issue with an injector o-ring??
Old Jul 15, 2011 | 12:15 PM
wuttrd's Avatar
wuttrd
smoke
thanks for the reply. i will have to try some different settings. i got paranoid to drive it, and the weather is only going to be 105 today so i drove the ghia. how big of an issue is a o-ring thanks
Old Jul 15, 2011 | 12:21 PM
Shake-N-Bake
Changing injector o-rings is a relatively simple procedure, you'll have to remove the injectors though. If you've never done it before then you should plan about 4 hours for the entire R&R process. Of course, we aren't sure what the issue is just yet...I was just throwing out a guess.
Old Jul 15, 2011 | 02:22 PM
wuttrd's Avatar
wuttrd
scan
gchavez
thanks again for the responcei have a buddy here in havasu with a scan tool, and he is going to hook me up on Monday to check codes. hoping that its something simple.i will post the results.
Old Jul 15, 2011 | 08:34 PM
cps's Avatar
cps
subscribing
Old Jul 15, 2011 | 09:00 PM
plgebbia's Avatar
plgebbia
My truck has been smoking a little lately too, (black) but it has gotten very humid and hot here, and that seems to be the only reason I can pinpoint.
Old Jul 15, 2011 | 10:44 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Mine smokes a lot and the egts will jump sometimes. It happens when I step on the pedal and I'm at a crusing speed. I have major boost leaks, so thats why causes mine.
Old Jul 17, 2011 | 09:48 AM
wuttrd's Avatar
wuttrd
re smoke
well i furged out what the black smoke issue was on take off. i got lucky, it was red hose for the waste gate for some reason it came off. guess i should check things over real good before freaking out. thank you for your replys .
Old Jul 17, 2011 | 12:05 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Boost related. Just like mine
rkbutz55
Jan 14, 2011 01:13 AM
pgjeepster
Aug 14, 2008 01:13 PM
rednek01
6.4L Power Stroke Diesel
32
Nov 29, 2007 09:57 PM
debestuss
Aug 31, 2004 08:44 AM
russtlm
May 23, 2002 03:39 PM
