i just buoght a 96 f250 psd 5spd its hard to get into first and reverse but shifts fine gonin down the road could it be the slave cylinder any help or comments will be apreicated thanks
The pedal box on the firewall below the dash has plastic bushings that like to wear out and cause the pedal travel to decrease, thus causing the hard shifting.
And check the fluid level in the reservoir. Mine was like that when the slave decided to develop a little leak and my reservoir got empty. A new slave fixed my problem.
can u tell if the bushings are shot in the truck or do u have to take the pedal assembly out to tell first thing i checked was the fluid level i drive a 91 F150 n the slave cylinder leaks on it thanks
With just 1st and reverse I'd suspect something not allowing the input shaft to stop before anything else. Pilot bearing. I've had a little problem with those lately. I just finished rebuilding my transmission because of it tearing up so many pilot bearings. It's fixed right now. If it was something with the clutch pedal then it would be weird in all gears. Open your windows and see if there is a chirping noise coming from underneath when you push the clutch in.
The rest of the gears are syncro'ed. They slide in without even pushing the clutch. I would vote for the clutch pedal bushing as well.
The rest of the gears don't have to stop in order to engage. The synchro ring and hib should take care of them but both sides are spinning. 1st and reverse do have to stop. Only one side is spinning when the pilot bearing has hold of the input shaft. The sliding sleeve on those two are near impossible to move if the input shaft is spinning on one side of it. The clutch pedal can cause it but I doubt that's it. The clutch doesn't have to go down very much to disengage the clutch disk and there is a lot of room for slop on it.
