Injector issue
Old Jul 17, 2011 | 06:24 PM
  #76
hotroddsl's Avatar
hotroddsl
Yes the high pressure oil system.
Old Jul 17, 2011 | 06:32 PM
  #77
bulla's Avatar
bulla
Check out this video on YouTube:
http://www.youtube.com/watch?v=OHcCXST2RxQ&feature=youtube_gdata_player
Sent from my iPhone
Old Jul 17, 2011 | 06:36 PM
  #78
bulla's Avatar
bulla
This is an example of me using the setup I just posted. It is a very handy setup! I have used it many times and has found or at least isolated the problem!
http://www.youtube.com/watch?v=tyDc2...e_gdata_player
Sent from my iPhone
Old Jul 17, 2011 | 10:26 PM
  #79
Shake-N-Bake's Avatar
Shake-N-Bake
Originally Posted by Jbrown8988
Ok we pulled the lpop and it was installed right. Damper mark towards front of truck. However the cover is grooved in some areas. Is this right ?
Would like to see some pics if possible. Everything I've found online so far sounds like the surfaces should be flat and smooth with just the pockets machined for oil flow. Maybe if you post some pics then others can comment on it's condition.
Originally Posted by hotroddsl
Bulla I believe that hole that was filling up is the vent line for the HPOP and will be sealed off by the gasket at that point not open untill the very top of the resivour, someone please correct me if I'm wrong!
I'm still not sure of the exact oil path but David's (Bulla) videos are helping me draw up a better picture. I think that hole is ported to the chamber that receives the IPR bypass oil. The early designs had a check ball for the IPR bypass to return to the sump but the design was changed on the Super Duty models so the oil was pumped up a standpipe to the top of the reservoir and then returns to the sump. I think the return path is directly over the timing gears.
It was later determined that David had the incorrect HPOP gasket installed and that was allowing the oil to make it's way to the other side. The hole on the other side is the drain for the safety pop off valve, just in case the HPOP build too much pressure.
Thats the check ball that sits behind the non serviceable plug! And that makes some sense! If the HPOP is not oriented correctly while removing the plug it will fall out that's why it's not serviceable, on the truck any way, but it shares the galley with the IPR! It won't fall out if you change IPR's on the truck but I think it can if you rotate the HPOP
While off the truck? While changing ipr's on the bench??? Any one?
The check ball would be an excellent candidate for our problems here but Jim said he replaced the HPOP and didn't have it rebuilt. The mechanic did not mess with the non-servicable plug so that check valve can't be disturbed. Removing the IPR has no effect as far as I know.
Originally Posted by bulla
As far as I know it can only fall out if the non serviceable plug is pulled.
I believe you are correct David.
Just an update. I replaced the lpop with a melling pump. I will post pics later of the other housing. Changed the oil. And now it won't start at all.
Is the CPS unplugged by any chance?
The batteries were low but we charged them for an hour while putting things back together and then when we went to start it we put the charger on Boost. Yes there is smoke... whitish color smells like its trying to fire but just won't.
Also we pulled the ICP out again and oil shot out pretty good... a lot better than friday, friday it just slowly bubbled out and now it comes out fast.
Sounds like the cps is plugged in. Might need to let the batteries charge up for a while longer...
Jim,
Are you seeing oil pressure on the dash gauge while cranking?
I think I remember during one of our conversations that you said you purchased the HPOP for the mechanic to install. Did you get it from International or from Ford? Do you happen to have the part number by any chance? Did they ask you for your engine serial number when they looked up the part? There are four variations of HPOP units with two types of gaskets. An early gasket on a later pump could allow the reservoir to leak down. There is also an early and late style IPR valve. According to the Ford tech bulletin, the part updates were tracked by engine serial number so hopefully they used that number when looking up parts for your engine.
Old Jul 18, 2011 | 09:10 AM
  #80
Jbrown8988's Avatar
Jbrown8988
Got rained out today so we are tearing into it.
HPOP was still full this morning so that might be a good sign.
Old Jul 18, 2011 | 09:17 AM
  #81
nlemerise's Avatar
nlemerise
Jim, that is a great sign...Have you gained access to an AE? If you are going to keep this truck the investment in AE would be money well spent...Good luck today!
Old Jul 18, 2011 | 09:38 AM
  #82
Jbrown8988's Avatar
Jbrown8988
Closest I got was a guy with a scanner snapon. He said he could come out sometime this week.
Got the truck started with a tiny shot of ether. I no I no. So now it still has long cracking. But does fire.
Old Jul 18, 2011 | 09:43 AM
  #83
nlemerise's Avatar
nlemerise
Maybe you ought to post a new thread: AE REALLY needed in Oneida, NY area"? If I was anywhere near, I'd come by with mine and my laptop.
Old Jul 18, 2011 | 10:04 AM
  #84
Jbrown8988's Avatar
Jbrown8988
http://www.youtube.com/watch?v=Dhdvz...e_gdata_player
Sorry its upside down.
Old Jul 18, 2011 | 10:24 AM
  #85
cj45lc's Avatar
cj45lc
I'd say you are gonna have to run it up the road to work the air out of the system. Probably have to run it pretty good for a while.
Old Jul 18, 2011 | 10:51 AM
  #86
Shake-N-Bake
Thanks for the vid. Fitting that we would start the week upside down.
Your low pressure oil looks good. On my trucks, the gauge never moves until the engine fires, no matter how long I crank.
How does the truck drive? It'll take 30 miles or so to work the air out of the system.
Old Jul 18, 2011 | 01:25 PM
  #87
Jbrown8988's Avatar
Jbrown8988
Ok guys we ran the truck 20 miles and came home let it sit for a hour and fired right up! Don't wanna get my hopes up but I think we got it ny replacing the lpop and bleeding the air out.
Old Jul 18, 2011 | 02:30 PM
  #88
Shake-N-Bake
Crossing my fingers for you here in Arizona. Let's hope you got her fixed! And if so, then we now know that a bad LPOP CAN allow the HPOP reservoir to leak down. Maybe having good low pressure oil in the galleries reseated the cold start check ball? I sure would like to get my hands on an extra block and front cover so I can see exactly how the oil system works....
Old Jul 18, 2011 | 04:18 PM
  #89
Jbrown8988's Avatar
Jbrown8988
So far so good guys... if this thing stays running for me i am going to buy a AE from clay! Just wanna make sure i don't jump the gun and empty my piggy bank too soon!
Thank You all for the help...Saved me a lot of money! A special Thanks to greg(Gchavez) and David (Bulla) for taking the time to talk to me on the phone and figure this thing out!
Also i am thinking the LPOP finally completely died while we were trying to check for the oil coming out of the injectors and this could be the possible reason for the reservoir to empty out. Reason being is the truck should have started with all the cranking we did trying to see oil and also we never did see any oil... thinking that the HPOP pumped out all the oil in the reservoir and no oil came back in. Just a thought.
Old Jul 18, 2011 | 04:32 PM
  #90
Shake-N-Bake
Good thinking. AE will work with all 4 vehicles in your signature so it's really a no brainer if you ask me.
At least we all were right about two things....your mechanic was making WAGs and your injectors were fine.
