U-joint replacement
Old May 6, 2010 | 04:25 PM
f250red's Avatar
f250red
U-joint replacement
I need help sizing U-joint for my 54 f250.I am using the original driveshaft with a 9"rearend from an 81 ford van.I need a U-joint with two different size bearing caps.If anyone could help me with part numbers and brand names,I would appreciate the help Thanks F250RED
Old May 6, 2010 | 06:50 PM
vintage tin's Avatar
vintage tin
Napa is a good place for this.
if you know what year the 9"came out of then they should be able to match that with your stock u-joint.
my 9" takes 1330 and my t5 tranny takes 1310,they had this on the shelf.
i hope this helps.
Old May 6, 2010 | 08:24 PM
f250red's Avatar
f250red
U-joints
I tried these numbers at NAPA and Advance Auto,and the numbers would relate to anything.I need a company or brand name or manufacturer to pursue this further. Thanks F250RED
Old May 6, 2010 | 10:00 PM
mtflat's Avatar
mtflat
U joints are really simple - measure across the caps - both directions and measure both of the cap diameters. NAPA has anything you need - except a new parts jockey apparently!
Old May 6, 2010 | 10:39 PM
fifty-two_f1's Avatar
fifty-two_f1
Wow this is weird I just went yesterday and bought the exact u joint for my project that you are talking about. Anyway Napa has just what you need. They had mine in stock. If you dont want to measure then take the shaft and yoke in with you they will help you find what you need.
Old May 7, 2010 | 12:45 AM
BlueOvalRage's Avatar
BlueOvalRage
Vintage tin is right. Your OE driveshaft will want a 1310 series joint and most of the light trucks through the 80's and early 90's used a 1330 series joint. That's what it will take to mate up to your 9". The Spicer part number for the 1310/1330 conversion joint that you need to mate the two together is 5-134x. Most auto parts suppliers either use Spicer's numbers outright or will be able to cross reference them. Napa shows it in their NAPA Proformer brand as part# NPJ P353 and also in the Precision brand as part# PUJ 353. Here's the search if you are curious:
http://www.napaonline.com/Search/Res...mber&Nty=1&N=0
Old May 7, 2010 | 09:28 PM
f250red's Avatar
f250red
U-joints
Picked up a 353 Ujoint today it will fit the 9" rear end but is too wide for the original 54 f250 driveshaft,looks like I may have to change the yoke,I have to modify the drive shaft anyway it`s an1 1/2" too short.when I put the driveshafta the way forward on the spline,how far should I pull it back for an accurate measurement. Thanks F250RED
Old May 8, 2010 | 03:49 AM
BlueOvalRage
With the weight of the truck on the rear axle, you want about an 1" to 1 1/4" of yoke travel for suspension compression. You'll need a little more if the bed or anything major is missing to account for squat when it's all together.
I'm sorry that joint didn't work out for you. It sounds like something has been changed here with the driveshaft maybe. The books call for the same 1310 joint in all the F-100 through F-350's. Rather than guessing, it would be better to measure. Can you give me measurements of the cross width with the caps in place and also the cap diameter of both your driveshaft and the 9 inch's pinion yoke? The more accurate the measurements, the better.
Old May 8, 2010 | 05:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Ford part number; C5TZ4635F / Spicer-Dana part number: 210392-X .. U-Joint / 2 cups are 1310 / 2 cups are 1330.
SVandal
May 7, 2017 03:08 PM
SUPERDUTY_08
6.4L Power Stroke Diesel
Jun 28, 2016 05:48 PM
Scotty's 52 F3
Oct 25, 2015 01:20 AM
Tailgate55
Jan 16, 2014 07:02 PM
genscripter
Jan 29, 2013 11:42 PM
