flashing airbag light.
Old Oct 11, 2002 | 06:28 PM
marragtop's Avatar
marragtop
Old Oct 17, 2002 | 09:47 PM
huskeyone's Avatar
huskeyone
Would any of you kind gents know what I should do to "outen" the flashing airbag light on my 93 E150/351 5.8L club wagon??? I've got about 132,000 + miles on her, and was recently (bout 2 weeks ago) hit, more like smacked on the left rear qtr.panel? the area after the rear tire, but again, I wasn't hit directly, could the light be because of this? Can I just pull a fuse (so much for saftey restraint?)
Thanks for any info.
John
Old Oct 17, 2002 | 11:27 PM
nitro94's Avatar
nitro94
The light should be flashing a code. Can you supply that info? Something like 2 flashes, pause, 4 flashes, = a code 24.
Old Oct 20, 2002 | 04:12 AM
Phil G's Avatar
Phil G
Sorry to butt in, I have the same problem with my '92 Club Wagon. The airbag light just started flashing the code 51. I've not had any bumps or anything. I would appreciate it if anyone could tell me what this code means.
Thanks in advance
Old Oct 20, 2002 | 09:12 PM
huskeyone's Avatar
huskeyone
Thank you for the info!! The light is still flashing, I did not think to see if there is a pattern that would be a code. A few years back I bought one of those hand held scanners that you could connect to your engines computer and it would flash in a pattern that you could look up in a code book. This sounds like a similar diagnostic? I'll check this out tomorrow!! Thanks again!!
Old Oct 20, 2002 | 09:18 PM
nitro94's Avatar
nitro94
Phil G, my 2000 manual does not show a 51. Will check Alldata tomorrow.
Old Oct 21, 2002 | 09:31 PM
nitro94's Avatar
nitro94
I have the info. if you need it.
Old Oct 21, 2002 | 09:51 PM
huskeyone's Avatar
huskeyone
I checked the pattern of the light this afternoon, and it is flashing a code 45, I appreciate any further light you could shed!!!
Thanks
John
Old Oct 22, 2002 | 06:48 PM
robert56's Avatar
robert56
>shed!!!
>Thanks
>John
John,
According to my set of service manuals for a 1994 E-series, code 45 is " Radiator support center air bag sensor not mounted to vehicle properly". Maybe you have a ground fault for that sensor?
Rob
Old Oct 22, 2002 | 09:40 PM
huskeyone's Avatar
huskeyone
Rob, thanks so much for the info, I will check this out, I replaced the radiator a few years back, maybe something came loose, I believe in my Haynes manual there is a schematic that shows sensor locations.
Thanks Much!!
John
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
