Bad n Leaking Freeze Plug
Old Jul 11, 2011 | 03:51 PM
Bear108's Avatar
Bear108
My 97 F250HD has a 351w motor. One of my freeze plugs is seeping pretty bad. I have never replaced one before, but I hear it is not very hard at all. My problem is, my long tube header is exactly in the way of being able to replace it. My truck has almost 200,000 miles and I really don't feel like taking long tube header off. Truck won't last much longer. So my question is, I have been to about the rubber freeze plug, with washers, nut and bolt. Are they any good, do they hold up??
Old Jul 11, 2011 | 04:35 PM
nstueve's Avatar
nstueve
we use them at work for plugging exhaust emissions from stacks. They work ok but will fail sooner than the 351w will.
I'd check your cylinder compression and oil pressure... That will tell you the overall health of your engine. I had a buddy run his 95 351w up to 325,000 with good maintence and keeping up with what needed fixing. how are the headers put on? bolts or studs? Most guys who put headers on usually use stud kits in order for easy removal later along with copper antiseeze. if this is the case removing that header shouldn't be that much of a problem... PB blaster!!!!
OldFord72
Sep 12, 2014 05:18 PM
HomeRx
1997 - 2003 F150
Feb 9, 2011 07:35 AM
skrinar70
Jul 30, 2007 01:22 PM
2.9 ranger
New Member Introductions
Mar 12, 2006 08:12 PM
JohnT
Apr 23, 2005 05:56 PM
