Removing timing pointer
Old Jul 11, 2011 | 11:58 AM
jmf66's Avatar
jmf66
How do you remove the timing pointer on the 390? After removing the timing comver bolt, it's still got a rivet like attachment to the cover.
Old Jul 11, 2011 | 02:07 PM
MIKES 68 F100's Avatar
MIKES 68 F100
grind/drill the rivets off , then you'll have to tap the holes and use screws .
Old Jul 11, 2011 | 02:24 PM
jmf66's Avatar
jmf66
Thanks Mike!
Old Jul 11, 2011 | 02:37 PM
FFR428's Avatar
FFR428
Needsmorecoffee.
If the rivet is factory make a slot in the head and use a screwdriver to work it out. My early C3 and later C8 covers used screws. 2 small screws in the C3 and one small screw and cover bolt on the C8. They might have used a rivet later on one some covers? If so they might be like the intake valley pan rivets where you can work/pry them out. If the threads in the hole were stripped someone might have just tapped a rivet in there. All the covers I've had the hole/holes were threaded.
Old Jul 13, 2011 | 08:25 AM
jmf66's Avatar
jmf66
Update... after I got the water pump off, I saw that it's not a rivet, but a small screw with a 5/16" head.
btw, I'm not sure on the history of this 390.. the heads and 4V intake are C8, but the balancer is the 67 and earlier style.. which I'm changing out to a 3-hole from the early 70's
tonpartain
Mar 22, 2006 08:45 AM
MustangGT221
Dec 3, 2004 05:04 PM
merkstang
Jun 1, 2004 06:09 PM
wytfut
Apr 8, 2001 03:54 PM
