Windshield Installation
Old Jul 11, 2011 | 11:31 AM
old_dan's Avatar
old_dan
There was a little discussion on installation of windshields last week....so I documented my installation this weekend with a few photos! Here's the process:
Test fit the seal to the clean glass:
Clean the sealing surface on the windshield frame in the cab...
Here's the sealant that I used....I picked this up from the classic Mustang shop that is around the corner from my office:
Put a small bead of sealant in the grove of the seal...this is the glass to rubber seal
Press the seal onto the glass & wipe off the excess with paint thinner and clean paper towels....wear some nitrile gloves
Put a thin rope into the seal. It has to go all the way around
Here's another view of the rope going in...
Now...put a bead of sealant in the frame. This will be the seal of the rubber to the metal.
Here's the bead:
Put some soapy water on the inside part of the seal where it has to slide over the windshield frame
Slide in one corner of the seal & press the windshield into the frame
Here's where you need a helper!
Start pulling the rope to slip the seal over the frame
While you're pulling, have yout helper maintain firm pressure so the seal is against the frame while you pull the rope
And viola! Windshield is installed!! Wipe off the excess sealant with some paint thinner!
Old Jul 11, 2011 | 12:43 PM
r_reed's Avatar
r_reed
good pics, thanks.
Old Jul 11, 2011 | 01:00 PM
mechmagcn's Avatar
mechmagcn
Thanks for the tutorial. I wish I had used the butyl during the install instead of after, much neater and easier to clean up
Old Jul 11, 2011 | 05:43 PM
Wayne S's Avatar
Wayne S
Nice.Thanks for the step by step.I will be installing my glass soon and will
use this info.Added to favorites.
Old Jul 11, 2011 | 06:05 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Thanks Dan, Ill file this one in my how to folder, you did a great job on it.
Old Jul 11, 2011 | 08:42 PM
iwanaflattie's Avatar
iwanaflattie
thanks. should be a sticky
Old Jul 11, 2011 | 09:28 PM
Mr Mayo's Avatar
Mr Mayo
Bring out the best!
Thanks for taking your time to post this.
GreatNorthWoods's Avatar
GreatNorthWoods
Nice job on the documentation!
Old Jul 11, 2011 | 11:42 PM
51PanelMan's Avatar
51PanelMan
That windshield looks really nice!
Looks like I'll be the "helper" when you help me install the windshield in my 52 once I get the new rubber for the 5 Star trim.
Old Jul 12, 2011 | 01:07 PM
52 M1 Kootenay Kid's Avatar
52 M1 Kootenay Kid
Thanks Old Dan for the wonderful and informative post.I agree your post should be saved somewhere (tips and tricks maybe?)
All the best!
Old Jul 12, 2011 | 03:42 PM
old_dan's Avatar
old_dan
Thanks for all of the kind words....and yes Ilya....we'll do your windshield as soon as you have the seal.
The part that doesn't show up well is the fact that the sealant oozes out around the whole seal & it took an entire roll of paper towels, several pairs of nitrile gloves and a bunch of paint thinner to clean the excess. Since the sealant doesn't really ever dry, there is no big rush to clean up the mess.
Dan
Old Jul 12, 2011 | 06:33 PM
55f100tx's Avatar
55f100tx
Great, im going to save this in my favorites. i hope my 55 windshield goes in as well.
Old Feb 15, 2012 | 04:33 PM
koyler's Avatar
koyler
Thanks so much answered all my questions!
Old Feb 15, 2012 | 06:12 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
So for a 5 Star Extra trim, do you install that first or last?
Old Feb 15, 2012 | 06:22 PM
51PanelMan's Avatar
51PanelMan
For the stainless w/s trim, make sure that the tabs in the cab's w/s opening are cut off, then insert the trim into the weatherstrip and install the windshield.
Short answer, install s/s trim before you install the glass into the cab.
