Windshield Installation
Old Aug 19, 2012 | 05:41 PM
  #31
hotrodbob51's Avatar
hotrodbob51
This could not have come at a better time. I just ordered my windshield should be here by the end of the week.
Thanks
Old Aug 19, 2012 | 06:47 PM
  #32
CarlH's Avatar
CarlH
Windshield installation
Right. But now you have to find out where to obtain that CRL Windshield and Body Sealant!
CarlH
1949 F3 Express
Old Aug 19, 2012 | 10:32 PM
  #33
old_dan's Avatar
old_dan
If all else fails call Mustang Fever in Santa Clara CA. On Reed Street.
Old Aug 19, 2012 | 10:48 PM
  #34
Jolly Roger Joe's Avatar
Jolly Roger Joe
CarlH
1949 F3 Express
Amazon has it cheap:
Amazon.com: C.R. LAURENCE CRL7708 CRL Windshield and Body Sealant: Home Improvement
Old Aug 28, 2012 | 12:06 PM
  #35
CarlH's Avatar
CarlH
What to do with the four tabs?
On my '49 there are four tabs sticking up where the rubber seal goes. Cut them out? Bend them down and back up again?
CarlH
1949 F3
Old Aug 28, 2012 | 06:21 PM
  #36
51PanelMan's Avatar
51PanelMan
You can keep the tabs. However, if you plan on installing the stainless steel trim from a 51-52, then the tabs need to be removed.
Old Sep 5, 2012 | 08:38 AM
  #37
CarlH's Avatar
CarlH
Oh, what a mess!
Dan, you sure made it look easy! Putting the windshield sealer in the glass groove went well, but that #&@! gasket slithered like a snake as I installed it on the edge of the glass. I should have had a helper. The black goop spread everywhere, the gloves stuck to the adhesive pulling the rubber gasket loose and pulling the gloves off, so I jettisoned them and ended up covered fingers to arms with the black, sticky stuff! What fun!
Next day, the rope trick worked well (I had a helper pushing in on the glass.) and the windshield slipped into place nicely. More black goop seeped out around the frame and a big clean-up job followed. I took a bath in lacquer thinner!
But thank you for your step-by-step instructions. The job is done. The windshield is in place. I can move on to the side and vent windows. Oh, maybe next year.
CarlH
1949 F3 Express
Old Sep 7, 2012 | 12:36 AM
  #38
old_dan's Avatar
old_dan
Carl,
It's not an easy job....I went through a roll of paper towels and half a box of the nitrile gloves. I use plain old paint thinner on a paper towel to wipe off the excess goo as it started to squeeze out.
It sounds like it went well!!! Congrats!!
Dan
Old May 1, 2014 | 10:01 PM
  #39
fbb1951's Avatar
fbb1951
My wife and daughter and I installed the front and back windows in my '51 F1 today. Thanks Dan for the super tutorial. I have been avoiding this task for a while now. Thanks to the pictures and instructions, it went smoothly. The clean up was the biggest part. The 5 star trim did add another level of difficulty though, getting the stainless to lay flat.
Old May 1, 2014 | 10:37 PM
  #40
old_dan's Avatar
old_dan
You should post some pics!!
Old May 2, 2014 | 07:40 PM
  #41
jonf's Avatar
jonf
Sealer necessary??
Did Henry's assembly line workers use that sealer?
Old May 3, 2014 | 07:45 AM
  #42
fbb1951's Avatar
fbb1951
The window that i removed from the truck last fall did not have any sealer that I could see. Neither on the windshield nor the back window. However the windshield did leak in the lower right corner, and someone had used silicone to attempt a fix there.
Old May 3, 2014 | 09:20 AM
  #43
johnnydevil55's Avatar
johnnydevil55
Would'nt it be better to install the gasket dry to see how it fits, then mask off the windshield with painters tape around the edge of the gasket? that way it cuts down on wiping away excess sealer? i may be wrong. i have never installed a windshield, i have removed a few but that's it.
Old May 3, 2014 | 09:46 AM
  #44
fbb1951's Avatar
fbb1951
Some before and after of the F1 glass install. No pics of the actual install process, hands were too busy.
Old May 4, 2014 | 10:21 AM
  #45
Rimrock F1's Avatar
Rimrock F1
Brent, that looks great as does the whole truck. Good job on the glass install!
