Windshield Installation
Old Feb 15, 2012 | 06:40 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Originally Posted by 51PanelMan
For the stainless w/s trim, make sure that the tabs in the cab's w/s opening are cut off, then insert the trim into the weatherstrip and install the windshield.
Short answer, install s/s trim before you install the glass into the cab.
So do the tabs exist in a 5 Star Extra cab? And do you use the same adhesive for the S/S trim?
Old Feb 15, 2012 | 07:13 PM
51PanelMan's Avatar
51PanelMan
If the truck is a 5 Star Extra Cab from the factory, then the tabs would be already cut. No adhesive is needed for the s/s trim. It's held in by the pressure of the weatherstrip and installed windshield.
Just for reference
Tabs (located on top and bottom of the windshield opening frame)
No Tabs (trimmed from top and bottom locations)
Old Feb 15, 2012 | 07:34 PM
Jolly Roger Joe
Thank you sir! That's what I needed to know.
Sorry for the hijack...
Old Feb 15, 2012 | 07:48 PM
51PanelMan's Avatar
51PanelMan
Not a hijack. It's still relevant to the windshield installation.
Old Feb 16, 2012 | 11:30 PM
smallello's Avatar
smallello
Are we there yet?
Nice work! That paint looks sweet too!
Old Feb 18, 2012 | 06:27 PM
Krhitchings's Avatar
Krhitchings
thanks for posting that up. much appreciated
Old Feb 19, 2012 | 08:19 PM
opkomdalen's Avatar
opkomdalen
Thanks for the step by step with the photos! I plan on replacing this seal this spring and this will sure help.
Old Feb 19, 2012 | 09:31 PM
27TV8's Avatar
27TV8
Many thanks! I have a 48 and have the stainless trim from a 5 star, I would have struggled to put in the glass with the four tabs still on. Looks like they are going to be cut out!
Thanks again. This Forum is great. 48 Ford Half Ton Pick Up.
Thomas
Old Feb 19, 2012 | 09:39 PM
51PanelMan's Avatar
51PanelMan
Thomas
If you don't cut them, you'll be buying yourself another new windshield.
P.S. This info is also in the service/repair manual.
Old Feb 29, 2012 | 03:16 PM
iwanaflattie's Avatar
iwanaflattie
Hey
So is it ok to NOT use the sealer (slilicone).?
Old Feb 29, 2012 | 03:58 PM
old_dan's Avatar
old_dan
Everybody that I asked, including my friend the auto glass guy, and the guy from the Mustang shop....you want some kind of butyl sealer that doesn't harden. Either the stuff in the tube, or the butyl rope. They both said to stay away from silicone sealers.
Dan
Old Feb 29, 2012 | 04:05 PM
iwanaflattie
Thanks Dan,
I was planning on not using any but Ill wait and buy some,
thanks
Old Feb 29, 2012 | 06:02 PM
  #28
rhopper's Avatar
rhopper
May I add, get a large suction cup to help hold the glass. It also lets you pull the glass in instead of pushing on it.
Old Feb 29, 2012 | 06:11 PM
  #29
petemcl's Avatar
petemcl
Dan
If your painter will appreciate that also. That stuff plays Hll with paint booths.
Old Aug 19, 2012 | 04:51 AM
  #30
CarlH's Avatar
CarlH
Windshield rubber adhesive
Thanks, Dan. That's what I was looking for.
CarlH
1949 F3 Express
