Need tech. help!!!!! Please.
Old Jul 10, 2011 | 03:35 PM
Swamp Lizzard's Avatar
Swamp Lizzard
Just completed EGR delete and rebuilt oil cooler. Reinstalled EGR valve to rid EGR codes. Ran great for a couple minutes and then threw code 2084. I drove the truck about 20 miles to hopefully rid any air in the HPOP, Checked all elec. conections, and checked for oil leaks. I can find nothing wrong. The truck starts right up like a champ and the proceeds to act eratic. Acts as if someone was bouncing their foot on the foot feed. If you put the pedal to the floor, you would think 25hp has been added. Runs like a scalded beast, but with the pedal is pushed to anything less than 3600rpm the truck surges and even sometimes will cut out to the point I think it died. Three seconds later and its bouncing rpms again. I unplugged the IPC and then the truck threw a 2085 and 2084. Cleaned terminal which looked perfectly clan and pluged it back in. Threw the 2084 code only. Cant get any accurate readings on the scan gage due to no type of throttle controll. After it warms up engine temp is showing 102. Any help will be greatly appreciated.
Old Jul 10, 2011 | 03:56 PM
wulfman's Avatar
wulfman
Swamp lizz check the ficm plugs make sure they are in right and all ele connections. Just a thought
Old Jul 10, 2011 | 04:08 PM
rdunagan's Avatar
rdunagan
sounds like IPR
Old Jul 10, 2011 | 04:18 PM
BLADE35's Avatar
BLADE35
Originally Posted by rdunagan
sounds like IPR
+1 here
it doesnt take much junk to plug the screen
probably wouldnt hurt to pull it and just check the screen out
read this link on the IPR check out how small screen is and its operation
2005 Update Page 04 Turbo High Pressure pump/Discharge tube-Oil Branch Tube-IPR Valve
Old Jul 10, 2011 | 04:19 PM
Swamp Lizzard
I will check the ficm plugs. I may be getting the ipr and the ipc confused, and I have read where people had problems with it after changing oil cooler. It just seems funny that at that exact time the ipr goes out.
Old Jul 10, 2011 | 04:27 PM
Swamp Lizzard
Can you clean the filter or does or is the only fix to replace the IPR?
Old Jul 10, 2011 | 04:28 PM
wulfman's Avatar
wulfman
Yes IPR problems do happen you have to keep the engine valley super clean while doing it, has happened to a few on here.
Old Jul 10, 2011 | 04:30 PM
wulfman's Avatar
wulfman
I think you can clean it if its not tore if its tore then trash got in it
Old Jul 10, 2011 | 04:37 PM
Swamp Lizzard
I will check these possable causes and get back with you. Thanks fellas!!
Old Jul 10, 2011 | 04:47 PM
BLADE35's Avatar
BLADE35
I do beleive that you can buy just the screen for the IPR hopefuly someone will come post a part #
Old Jul 10, 2011 | 05:06 PM
Swamp Lizzard
OK, took out my IPC and mine doesn't have a filter. It looks just like the photo but no filter, unless it came off and is inside. Any Ideas?
Old Jul 10, 2011 | 05:36 PM
BLADE35's Avatar
BLADE35
so you took the IPR out right the one under the turbo
sounds like the screen sucked up inside it
IPR is under the turbo
ICP is in passenger valve cover
just making shure we are on same page
sounds like its time to replace the IPR
Old Jul 10, 2011 | 05:48 PM
Swamp Lizzard
We were on different pages. Do I have to remove the turbo or is there another way in?
Old Jul 10, 2011 | 06:01 PM
BLADE35's Avatar
BLADE35
heres a pic of the IPR location
I will try and find a better pic
Old Jul 10, 2011 | 06:05 PM
Swamp Lizzard
Looks like I will have to remove the turbo. Not cool!!!!
