2002 explorer codes
Old Jul 10, 2011 | 09:49 AM
Mustang6t7's Avatar
Mustang6t7
2002 explorer codes
On my 2002 explorer I get a code P1151 Bank 2 sensor 1 switch port lean.
Could this be a bad oxygen sensor? Located before the convertor
Old Jul 10, 2011 | 12:14 PM
shorod's Avatar
shorod
It could be, but it could be a lot of other things as well. Per the factory service manual, below are possible causes for this diagnostic code:
Electrical:
  • Short to VPWR in harness or HO2S
  • Water in harness connector
  • Open/shorted HO2S circuit
  • Corrosion or poor mating terminals and wiring
  • Damaged HO2S
  • Damaged PCM
Fuel System:
  • Excessive fuel pressure
  • Leaking/contaminated fuel injectors
  • Leaking fuel pressure regulator
  • Low fuel pressure or running out of fuel
  • Vapor recovery system
Induction System:
  • Air leaks after the MAF
  • Vacuum leaks
  • PCV system
  • Improperly seated engine oil dipstick
EGR System:
  • Leaking gasket
  • Suck EGR valve
  • Leaking diaphragm or EVR
Base Engine:
  • Oil overfill
  • Cam timing
  • Cylinder compression
  • Exhaust leaks before or near the HO2S(s)
These same possible causes are listed for both rich and lean indications, so obviously some of these won't apply for a lean condition.
-Rod
V8Ranger302
Nov 7, 2010 03:39 AM
wantford
Feb 28, 2010 02:38 PM
genesiss
Dec 11, 2009 06:56 PM
stunod2002
Oct 9, 2004 10:17 PM
autocarecenter
Jul 22, 2004 08:05 AM
