1995 Explorer Whinning
Old Jun 13, 2011 | 11:57 AM
MobilePC's Avatar
MobilePC
Hello, I've read several posts regarding similar whining from an explorer but mine seems a bit different: My wife’s 95 exploder whines from the front end, all most, all of the time. It is related to vehicle speed as it gets louder the faster that you go and does not stop or change during acceleration or coasting or if in neutral. The sound goes away if I’m turning left on a "sweeping curve" at a good speed and it also stops if I drive over a bump: the kind of bump that the vehicle kind of "floats" after. Meaning: the truck's weight in not fully on the suspension yet. As soon as it “lands” the sound immediately returns.
I’m wondering if this would indicate a Driver’s side bearing. (Less weight on that side while turning left and while flying through the air) Any advice will be greatly appreciated.
Old Jun 14, 2011 | 02:34 PM
wickware's Avatar
wickware
Have you checked power steering fluid, belts and bearings on the front of the engine's accessories? An old test was to start the engine w/o belts (turning any accessories). Good Luck, jow
Old Jun 14, 2011 | 05:26 PM
MobilePC's Avatar
MobilePC
Thank you for the reply! I don’t think that it could be the PS etc. If, at 40 MPH, I put it in neutral and let the engine come down to idle the sound remains constant. As the vehicle slows (still in neutral) the sound decrease relative to vehicle speed.
Old Jul 9, 2011 | 10:28 PM
MobilePC's Avatar
MobilePC
Solved
Solved - In case this can help someone in the future - replacing the front hubs solved my issue and returned my explorer to its once quiet ride. It's remarkably easy and there's a great how-to vid on YouTube
Old Jul 10, 2011 | 09:10 AM
caseys's Avatar
caseys
xxxxxxxxxx
Old Jul 10, 2011 | 01:38 PM
MobilePC's Avatar
MobilePC
Link is here
Here's the link:
YouTube - ‪Auto Repair: Replace Front Hub Ford Explorer Sport Trac Mercury Mountaineer 95-05 - 1AAuto.com‬‏
tschrubb
225
Aug 13, 2014 01:33 PM
Pool Runner
2009 - 2014 F150
Dec 2, 2011 02:33 AM
kper05
6.7L Power Stroke Diesel
Dec 25, 2010 10:14 AM
kper05
Sep 11, 2010 10:55 PM
scottf4444
Jan 11, 2009 02:57 PM
