Sponsored by: Auxito
excessive play
Old Jul 10, 2011 | 09:39 AM
mjones6168's Avatar
mjones6168
excessive play
I have a 1999 Ford F150 4x4. When I start to accelerate, I am getting a vibration that only lasts for a second or two. It feels like it is comming from the left rear, but not sure. This happens more often when I am turning slightly, but occasionally does it when driving straight. I do have some side to side play in both rear wheels. Possibly excessive. Any ideas? Thanks,
mjones6168
Old Jul 10, 2011 | 12:58 PM
steve(ill)'s Avatar
steve(ill)
IF you have a limit slip rear axle that can happen. The tires need to turn differents speeds when you turn a corner. Normallly when turning from a stand still, you will get a "grabby brake" type shudder or vibration for a few feet.. THE clutch is not letting go. You caan get a tube of "friction modifier" at Auto Zone for about $8. and put it in with the gear lube and might help... Is it time for a lube change ?
Old Jul 10, 2011 | 02:48 PM
mjones6168's Avatar
mjones6168
Thank you for responding.
I had the rear end checked and fluid added about a month ago. It seemed to help a little but the problem still exists. It does feel like the clutch grabbing though. Tried adding a little friction modifier, but maybe I need to add more. Not sure at this point.
Old Jul 10, 2011 | 04:17 PM
Bluegrass 7's Avatar
Bluegrass 7
You have not indicated you had checked any possibilities out yet.
How about checking the Universal joints on the driveshaft first.
Limited slip won't cause a vibration driving straight ahead.
Caution on adding friction modifier to clear an issue.
Know what it does before you do.
Adding more further negates the limited slip function and defeats it as a performance help in traction situations.
If the ring gear/pinion has chiped teeth you may feel 'feed back' as well.
Spring mounts should be checked.
Good luck.
DonovanF250
Sep 15, 2014 06:16 PM
brown79
Alberta Chapter
Mar 7, 2012 11:57 PM
Rellim51
Aug 24, 2011 07:35 PM
SixtySix Ford
Sep 29, 2010 11:35 AM
96sherm
44
Mar 19, 2009 07:44 AM
