Sponsored by: Auxito
What's that clunking?
Old Jul 10, 2011 | 06:16 AM
Krindgen's Avatar
Krindgen
2001 F150 4x4 with 112k.
I know this is probably suspension related, and I know if I wanna keep this truck I should replace all of my rubber suspension parts, just looking to maybe narrow down the issue.
When I back out of the driveway, or pull in, I hear this "clunking." But it sounds like it's coming from both the front or back depending on whether going forward or reverse.
I had thought it might have been my tailpipes shifting and contacting my hitch frame. But it sounds more strucutral, like in the suspension, or drivetrain.
Just looking for ideas.
Old Jul 10, 2011 | 10:14 AM
keyul's Avatar
keyul
Sounds like it could possibly be a U-joint.
Old Jul 10, 2011 | 05:10 PM
Dave G.'s Avatar
Dave G.
Not a whole lot to go on. It could be a u-joint, if each time it clunks it's right when you change directions, like forward to reverse. Check around the u-joint bearings cups for rusty metal particles.
If the clunking primarily over rough or uneven ground, the causes are several. Deep pitched could be upper or lower ball joints or Pitman arm. A little higher pitched could be tie rod ends. Other causes would be broken shock mounting bolts ( or missing bolts ), stabilizer links.
A typical clunking noise could also be the drive shaft yoke just needing some grease ( on the splines ).
Dave
Old Jul 10, 2011 | 05:15 PM
Krindgen's Avatar
Krindgen
Didn't think of the U-joint, but I was thinking that that might need to be replaced as I've done a significant amount of towing.
I just looked, the bottom of the rear differential housing is wet, not dripping, but the housing has definitely been leaking, a closer look it may be the forward seal.
I also think there was a TSB about a clunking sound with this year truck, but it just started happeing for me.
Old Jul 10, 2011 | 09:39 PM
tiny1's Avatar
tiny1
Moderator & CL
I had to replace the pinion seal on my '01 around that time frame. Maybe that the rear diff has leaked some and the fluid level is low.
Old Jul 10, 2011 | 10:44 PM
wgotthardt's Avatar
wgotthardt
https://www.ford-trucks.com/forums/4...revisited.html
(page 2 has complete R&R instructions)
RSCHAP1
Mar 16, 2015 12:30 PM
Biggziff
6.7L Power Stroke Diesel
Jun 1, 2011 04:46 AM
rednekrebel28
20
Dec 29, 2010 07:45 PM
Trakk
Jan 11, 2006 08:53 AM
cherring
Apr 27, 2004 06:00 PM
