What type trans fluid ??
Old Jul 10, 2011 | 12:50 AM
05 f250 6 inch lift's Avatar
05 f250 6 inch lift
I'm planning on changing my trams fluid an filter an seen it says to use mercon sp. I never heard of that b4. Hoping u guys can tell me the proper fluid to use. An how many quarts would I need.
Also seen a canister up on the passanger framerail that the lines go to the trans. Anyone know what that is.
Old Jul 10, 2011 | 05:23 AM
wulfman's Avatar
wulfman
You have to use mercron sp or the new LV, can get only at dealer and filter only at dealer. It takes 8 quarts when you drain the pan.
Old Jul 10, 2011 | 05:51 AM
DPorter's Avatar
DPorter
The canister is the external trans filter.
Old Jul 10, 2011 | 05:53 AM
05 f250 6 inch lift
Thanks wildman for ur help.
Old Jul 10, 2011 | 08:15 AM
BobsF350's Avatar
BobsF350
Motorcraft Mercon sp or Valvoline Maxlife atf.
Ive been using Valvoline maxlife for the last 3 changes.I drain and refill the pan every 25k
Old Jul 10, 2011 | 08:48 AM
69cj's Avatar
69cj
You only have to change the external filter. You don't have to drop the pan. There is a drain bolt. The internal filter stops trees and boulders and only needs changing during a rebuild.
Old Jul 10, 2011 | 11:15 AM
jhinalabama's Avatar
jhinalabama
I use Valvoline Maxlife ATF. too good stuff. O'Riellys has the canister filter too.
Old Jul 10, 2011 | 11:27 AM
wulfman's Avatar
wulfman
Hey 05 f250 i would not use the valvoline max it is most likely cheaper, but only use the mercon sp or lv. The manuel only calls for the ford stuff and its not worth risking your trans for a few bucks
Old Jul 10, 2011 | 12:43 PM
smokersteve's Avatar
smokersteve
SP or LV. both work
Here is a link for how I change my fluid.
How To Get More Than 8 To 7 Quarts - Ford Powerstroke Diesel Forum
Old Jul 10, 2011 | 03:11 PM
swamp donk's Avatar
swamp donk
would the SP or LV be the same for an 04 f-250, and would that also be the same amount?
Old Jul 10, 2011 | 03:24 PM
BLADE35's Avatar
BLADE35
AGREED
very very very few problems with these trannys with the mercon sp/Lv
Old Jul 10, 2011 | 03:30 PM
ljutic ss's Avatar
ljutic ss
Same trans, same amount of fluid.
Old Jul 10, 2011 | 03:44 PM
swamp donk's Avatar
swamp donk
Ok thanks.
Old Jul 10, 2011 | 08:04 PM
Tampa250's Avatar
Tampa250
If you can find a shop locally that uses BG Products, I highly recommend their universal synthetic fluid. I am in the automotive industry and was lucky enough to take a trip to BG's plant in Wichita, KS. Very impressive operation and I got to spend time with their head engineer- even after 18 years in the business I learned A LOT during that visit. That company has done the R&D and truly knows automotive chemistry.
Bottom line is that their fluid meets the specs of most fluids, with a few exceptions. I did a full flush with their system, including the cleaning and conditioning chemical, and refilled with the synthetic fluid. There was an immediate and very noticeable improvement in the overall smoothness of the transmission. The fluid has been in for about 20,000 miles and all is well.
Old Jul 10, 2011 | 08:45 PM
BobsF350's Avatar
BobsF350
Maxlife is fully synthetic and a ford Mercon SP fluid its about 16.00 gallon
