Y block Bellhousing question
Old Jul 7, 2011 | 07:35 PM
Bill W's Avatar
Bill W
Question Y block Bellhousing question
Okay, is there a way to tell a 3 speed truck bellhousing from a 4 spd truck bellhousing? (Y block 292) are there part numbers i could look for? any measurements i can take?
looking to do a T5 swap.
thanks.
Old Jul 7, 2011 | 08:51 PM
fivestarmmd's Avatar
fivestarmmd
Bell Housing
The 3 speed has small mounting flange with 4 7/16 -14 threaded holes. The 4/5 speed has large mounting flange with 5 9/16-12 threaded holes with 3 on starter mount side.
Old Jul 7, 2011 | 08:58 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
You won't find any part numbers on parts after 1956, only casting or ID engineering numbers.
Since casting numbers are foundry marks, they cannot be cross referenced to Ford part numbers.
One 292 bellhousing was only used for a 3 speed (B8C-7505-A), but...another (B8Y-7505-A) was used for a 3 speed (F/P350 w/a T-87), F100/600's with a T-98 4 speed, F500/600 w/a 5 speed (also used in C/N/P Series').
These are part numbers, but won't be listed on the housing. If you do find marked numbers, I might be able to cross them over, might not.
Old Jul 7, 2011 | 09:26 PM
Bill W's Avatar
Bill W
Thank you both.... i have 2 of them to go look at tomorrow, maybe one of them will be a 3 spd bell.
Old Jul 11, 2011 | 06:30 PM
charliemccraney's Avatar
charliemccraney
If it's a vertical, not quite rectangular rectangle, it's a 3 spd. If it's a horizontal rectangle it's a 4spd.
Old Jul 11, 2011 | 06:38 PM
Bill W's Avatar
Bill W
Originally Posted by charliemccraney
If it's a vertical, not quite rectangulkar rectangle, it's a 3 spd. If it's a horizontal rectangle it's a 4spd.
i think i understand, your talking about the bolt pattern. thanks Charlie!
Old Jul 11, 2011 | 06:43 PM
charliemccraney
No prob. I've had a few drinks. The not quite rectangular rectangle I'm describing is actually a trapezoid.
Old Jul 11, 2011 | 06:54 PM
Bill W's Avatar
Bill W
another Q, do they use the same clutch shield?
Old Jul 12, 2011 | 08:37 PM
turbohunter's Avatar
turbohunter
Here is a four speed housing Bill.
I know it's not much but maybe it'll help.
Old Jul 12, 2011 | 11:42 PM
Bill W's Avatar
Bill W
Thanks for the Pic Marc! i know exactly what to look for now.
John_0063
Nov 30, 2016 10:25 AM
Rockydm
17
Feb 4, 2015 02:18 PM
8lugthug
May 27, 2014 09:40 PM
79F150EFI
Mar 26, 2014 11:36 PM
332_58 f100
Dec 30, 2007 11:10 AM
