Hardly any air flow
Old Mar 29, 2003 | 12:58 AM
Fusion's Avatar
Fusion
Hardly any air flow
I have a 81 f250 without air. The air flow coming from the the vents is pretty anemic, is this common for this year vehicle? Or is my blower motor on its last leg?
Old Mar 30, 2003 | 01:58 AM
steve83's Avatar
steve83
Hardly any air flow
What does "without air" mean - no air from the registers, or no air conditioning? Have you cleaned all the leaves out of the ducts? Can you hear the blower spinning? Does the speed switch seem to have an effect?
Old Mar 30, 2003 | 04:15 AM
Fusion's Avatar
Fusion
Hardly any air flow
Sorry, I intended no air cond. when I said "without air". I checked tonight and the speed switch seems to be screwed up, as switching from low air flow to medium flow works yet medium to high has no effect (the blower motor doesn't increase in speed). Are there cleanable contacts on the switch or should I find a replacement?
Old Mar 30, 2003 | 02:45 PM
steve83's Avatar
steve83
Hardly any air flow
I doubt a bad switch could produce that effect. It's more likely the motor or debris in the ducts, but even though the switch CAN be disassembled, I wouldn't waste the time on it. If it's bad, replace it.
HRSPLY
All Things Towing
15
Mar 27, 2021 07:29 PM
rainfree619
Aerostar
Aug 13, 2011 05:25 PM
quadzjr
Dec 12, 2005 11:59 AM
winfordr
Feb 9, 2002 08:49 AM
dynamic
Aug 7, 2001 02:43 PM
