Mas Air Flow Sensor
Old Feb 4, 2002 | 11:11 AM
winfordr's Avatar
winfordr
Mas Air Flow Sensor
Old Feb 6, 2002 | 08:55 PM
spiritwolf68's Avatar
spiritwolf68
Mas Air Flow Sensor
Can anyone tell me what size mas air flow sensor I have the #'s on it are XF2F-12B579AA & 9D09-1 & 7024631 & > PBT-CF30<. Also would It be a waste of money to go with a bigger one with just a K&N complete intake system. And what would be the biggest size I could go to?
Old Feb 6, 2002 | 09:24 PM
CobraXP's Avatar
CobraXP
Mas Air Flow Sensor
If you have the K&N FIPK, I would go with a Granatelli 70mm Mass Air. Anything bigger than that, and you would have to start thinking about changing injectors to match. It will help, I don't know how much on the 4.0 though. I have a 5.0, and am running a K&N FIPK, an 80mm mass air, 24lb injectors, a Superchips, custom exhaust w/ Motorsport headers, an AIRAID throttle body spacer, and a couple of other things also done also. I had to send my chip back to them to have it recalibrated when I changed injectors and went to the 80mm from a 70mm. Might want to check with them on it...
Oh yeah - I think your stock size is either 55mm or 60mm. Not sure...
Good Luck and let us know what you do!!!
Old Feb 9, 2002 | 08:49 AM
spiritwolf68
Mas Air Flow Sensor
Thanks, I ordered a Granatelli 70mm w/cold air tuning.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Oklahoma Chapter
Apr 11, 2003 10:33 PM
walterdanek
16
Feb 16, 2001 07:56 PM
