EGR Delete
Old 07-06-2011, 12:05 AM
LKCKR's Avatar
LKCKR
LKCKR is offline
EGR Delete
What is anybodys take on a EGR delet kit for the 6.0's? I just dropped 1500 large on getting my EGR valve and intake cleaned and I really don't want to do it again.
Thanks
Tom
2004 F350 Lariet PSD
128000 Mi.
No Chip as of now, I just took my Edge Platinum off
Old 07-07-2011, 09:26 AM
Help I M Stuck's Avatar
Help I M Stuck
Help I M Stuck is offline
I did it on my 05 60+K miles ago and couldn't be happier. While my truck was in the dealer getting the EGR valve and cooler replaced.. I ordered the delete parts along with 4inch turbo back Magnaflow exhaust.
Old 07-07-2011, 12:34 PM
j540's Avatar
j540
j540 is offline
For sure take it out, Why deal with all the crap it puts back in yer motor and turbo, i did mine with just freezzzz plugs and a exhuast pipe expander tool so you can knock down the bypass ramp in the Y PIPE, Not all of the Y pipes have them. my 04 truck did not but my 05 Excurison did. just heated it up thru the hole that conects to the EGR cooler. then put the expander tool in the short side the expand it to close it up. just get it red hot and use a impact gun.
Old 07-07-2011, 02:20 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
i got rid of my egr and cooler,and im so glad i did,just a little piece of mind knowing thats 2 less things that can fail.plus i can tell a little difference in throttle response.
Old 07-07-2011, 02:40 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
j540- glad you tried it because that is something i would never advise anyone to do. thats way to risky! and the delete isnt really the best way to go. i would have done a bullet proof egr cooler and a sct tuner to shut the egr valve off. its the same thing as a delete but everything is there. yes i know i have a delete but if i was taught better when i did it i would have done the bullet proof egr
Old 07-07-2011, 03:01 PM
j540's Avatar
j540
j540 is offline
Yes with the SCT turner would be a better way to go because you wont get the Check engine light. price wasn't a factor in my deal I just needed it right now so it was a time isue, But not sure about the risk factor, you have them in yer block. And they cant come out unless you pull it apart.
Old 07-07-2011, 03:14 PM
rdunagan's Avatar
rdunagan
rdunagan is offline
are you talking about the "little director sheild" in the up pipe? from what i am understanding you took that sheild and use it to block off the pipe to the egr cooler correct? thats whats risky to me if im understaning it right.
brkncly
6.4L Power Stroke Diesel
08-02-2012 08:25 PM
toms911
02-21-2012 10:15 PM
LKCKR
07-06-2011 10:53 AM
Jbru167
12-07-2010 04:24 PM
ford4x4956
06-15-2010 12:12 PM
Quick Reply: EGR Delete
