riffraffs ebpv delete
Old Jul 4, 2011 | 11:54 PM
bryanlindborg600's Avatar
bryanlindborg600
i have been thinkin about truly doing the ebpv delete and getting the blank pedastal from clay at riffraff, it seems like a very fair price! my question is: is there other things i should do well i am there with the turbo off, need it or not i would almost rather replace something well i am there then go back in later on.. there is a common problem leak wise back there right? i can't remember right now what it is, any thought on what to do/what you would do well you are there would be appreciated..
Old Jul 5, 2011 | 08:06 AM
Talyn's Avatar
Talyn
Just need 2 sets of o-rings for pedestal and turbo.
And just need to gut the exhaust side of the turbo and throw in a 3/4 freeze plug in the hole.
Old Jul 5, 2011 | 02:14 PM
bryanlindborg600
I've gutted the exhaust side already, I just wanna get rid of the oil leak potential.. so just the o-rings is the only thing I should do well the turbo is off..? Nothing else to check and or replace in a preventive measure..? I'm going to see if clay has the o-rings right now.
Thanks
Old Jul 5, 2011 | 02:41 PM
MONAVIERONJON's Avatar
MONAVIERONJON
Easy to weld up the OEM ebpv pedastal holes if ur good at aluminum
Old Jul 5, 2011 | 04:07 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
Thanks
Riffraff Diesel: Garrett TP-38 Blank/Deleted Pedestal
O-rings are listed under the related items at the bottom of the product page.
Old Aug 29, 2011 | 11:15 AM
Blackdog 15's Avatar
Blackdog 15
Question....if you decide to weld the pedestal ...do you have to weld the hole where the rod comes out and the other larger end where the snap ring and cover plug are ? I saw one video where the guy tapped the rod hole for 1/4" pipe threads, put in a plug, then re-installed the large plug and snap ring on the other end... also have seen the large end cut off at an angle and welded shut along with the small rod hole..either way..no problem (am a heliarc welder by trade)...do aluminum pressure work daily...just want to know what works best...
Also when you drop out the butterfly from the turbo outlet (just ground out the 2 rivets & removed it and the shaft....is all I need to do to complete this operation is install a 3/4" freeze plug in the one side to seal it up.. I noticed there is a small snap ring/split ring on the outside of the bushing..I assumed that it can be removed too...
Old Aug 29, 2011 | 10:22 PM
Talyn's Avatar
Talyn
To answer your first question, the reason you remove the cylinder is for flow purposes, as well as for access to removing and installing the pedestal.
To answer your second question. I have no clue about any snap rings on the exhaust outlet for the EBPV.
here is a picture of my welded pedestal.
I know its different, cause it came on the 94's that way. =)
Old Aug 30, 2011 | 09:12 AM
MONAVIERONJON
Def weld the hole where the rod unthreads from,and cut about 2/3 of the aluminum circle flush with the base then weld up thos small holes thus making a completely sealed sytem.The snap ring and piston gets tossed out then.
Old Aug 30, 2011 | 10:00 AM
Blackdog 15
so I should basically cut the whole cylinder casing back....and weld it shut... how bout the area with the solenoid rod...was wondering how it comes off..I pulled the nut and slid the unit with the 2 wires & plug off, but the "bolt" doesn't want to come out...I see the is a very small freeze plug on the side of the housing below the rod....
Old Aug 30, 2011 | 10:43 AM
Talyn's Avatar
Talyn
that freeze plug is from the machining processes, dont touch it.
with the newer style ones, the actuator is different than mine.
I belive a lot of guys just leave them in or cut it and weld it.
if you use some vice grips and some heat you should be able to get it out though.
here is another picture from mine after I cut and polished it.
Old Aug 30, 2011 | 10:58 AM
Blackdog 15
Thanks..will try and pull the shaft..then weld hole shut...
Old Aug 30, 2011 | 12:34 PM
VIPERK30's Avatar
VIPERK30
I bought the pedestal from Riffraff. Made by Garrett. Nice piece. I rebuilt the turbo while I was at it. It's a lot easier to get the bolts on the pedestal back on with the new one!! Turbo is easy to rebuild. $100 for the parts.
Old Aug 30, 2011 | 01:31 PM
Talyn's Avatar
Talyn
yea, you can get the rebuild kit from clay also.
agsmv1
Aug 15, 2021 07:36 PM
paintubturner
Nov 29, 2016 01:19 PM
20powerstroke02
55
Oct 31, 2016 06:38 AM
JJD
Aug 1, 2016 11:01 AM
mrm8174
26
Aug 22, 2015 04:00 PM
