EBPV Delete Questions.....
Old Nov 29, 2016 | 08:56 AM
paintubturner's Avatar
paintubturner
I have decided to do a EBPV delete by buying a blank pedestal and high flow outlet for my 97 f350. Any suggestions on who has the most reputable parts/sales for a item like this? I have done some internet searching and found one for a decent price at Riffraff. Any opinions/suggestions would be appreciated.
Also, when we put the outlet and pedestal on we can leave the old EBPV on the truck and just unplug it?
Garrett TP-38 Blank/Deleted Pedestal - 7.3L Ford Powerstroke 94-97
Old Nov 29, 2016 | 09:12 AM
knottyrope's Avatar
knottyrope
you picked a great source already
just leave it unplugged and you wont need the valve anymore
Old Nov 29, 2016 | 09:21 AM
Jarrett Campbell's Avatar
Jarrett Campbell
You can drill out the rivets in the EBPV butterfly valve, pull the actuator arm out, and put a freeze plug in the hole... you'll have a "high flow" outlet for $0.70
Old Nov 29, 2016 | 09:40 AM
echo95's Avatar
echo95
I used the Riffraff delete pedestal as well. I also gutted the outlet/EBPV and used a freeze plug to plug the shaft hole.
When it comes to the wiring, I left the coil part (the round thing with wires attached that fits over the EBPV solenoid) hooked up and just leave it there in the valley under the turbo. This way I don't get any codes as I live in WA now, and have to pass emissions testing.
Old Nov 29, 2016 | 10:45 AM
compaddict's Avatar
compaddict
I did the pedestal delete too. Had the holes welded. Also picked up an EBPV dummy plug to stop CEL from eBay.
Old Nov 29, 2016 | 12:31 PM
BBslider001's Avatar
BBslider001
The CEL shouldn't show with it unplugged. None of my 3 trucks did.
Old Nov 29, 2016 | 12:32 PM
compaddict's Avatar
compaddict
Might be something different with my CA truck?
BBslider001
Shouldn't be...my last truck was a CA truck
Old Nov 29, 2016 | 12:46 PM
compaddict's Avatar
compaddict
Mine needed it. 1997 CA
Old Nov 29, 2016 | 01:07 PM
z31freakify's Avatar
z31freakify
It leaves a soft code with out the CEL.
Old Nov 29, 2016 | 01:19 PM
knottyrope's Avatar
knottyrope
some states like mine check for soft codes unless exempt
lucky I am exempt after 20 years
ajbrown208
Apr 1, 2017 08:12 PM
bike_guy123
Jan 22, 2013 08:50 PM
Powerstroke-7.3
Feb 12, 2012 10:07 PM
lazerf250
Jan 21, 2008 08:13 AM
94 1/2 stroker
18
Mar 5, 2006 03:52 AM
