would this work??
Old Jul 4, 2011 | 05:02 PM
moebutt's Avatar
moebutt
would this work??
installing a tpms sensor in a pvc pipe and pressurizing it, then zip tie it to the frame somewhere?
Old Jul 4, 2011 | 05:05 PM
Marauder92V's Avatar
Marauder92V
To full your warning system? You'll need to put all 4 in there... But if it can hold pressure, I don't see why not.
Old Jul 4, 2011 | 05:35 PM
jrtraderny's Avatar
jrtraderny
Nope they have to spin................
Old Jul 4, 2011 | 05:40 PM
wtrlogd's Avatar
wtrlogd
My understanding is that the sensors need to be spinning in order to transmit the information that the Body Control Module is looking for, so, no it wouldn't work.
The dealer can, using the IDS software, lower the BCM settings. I was told the minimum setting is 50psi, which is what all four of mine were set to, keeping me from having to re-train wheel positions when it comes time to rotate.
I've been running 65 front 55 rear with no more idiot lights since the mechanic did this for me, haven't tried lowering any more than that, yet.
Old Jul 4, 2011 | 05:50 PM
carpbob's Avatar
carpbob
to keep the rear that low you must not haul anything
Old Jul 4, 2011 | 06:41 PM
wtrlogd's Avatar
wtrlogd
Empty most of the time, and easy enough to air up with the full size air compressor in my tow hauler.
Try running dirt roads, empty, with 80psi in the rear.
Old Jul 9, 2011 | 03:29 PM
lakedweller's Avatar
lakedweller
Must be a way to disable the option.....(Annoyance)
Greywolf
19
Feb 29, 2012 01:37 AM
RookieFixer2011
Dec 19, 2009 02:02 AM
oldirtytruck
Modular V10 (6.8l)
17
Feb 3, 2009 10:23 AM
400944
Apr 20, 2008 01:44 PM
glruff
Delaware Chapter
Nov 21, 2007 08:53 PM
