Aerostar Ford Aerostar
Battery not charging
Old Jul 6, 2011 | 02:45 PM
Kmega99's Avatar
Kmega99
2 car batteries running through a special circuit was used.
Old Jul 6, 2011 | 03:04 PM
Roger1960's Avatar
Roger1960
Originally Posted by Kmega99
The success that I have experienced with my device is that when it's powered it will run the van for 7 minutes with the fuel pump unplugged. When the device has not been hooked up the van dies within seconds after the fuel pump has been unplugged.
Those are the results with the best design that I have built so far.
The word "success" is misleading. You make observations and draw data from the observations.
If your observed data meets your expectations then perhaps it is a success or perhaps not.
How do you explain why the engine only runs for 7 minutes and not 8 or more minutes?
Did you try depressurizing the fuel injection line during the 7 minute cycle?
Old Jul 6, 2011 | 03:33 PM
Kmega99's Avatar
Kmega99
After I complete the full system I'll know everything. Right now me getting a 7 minute run time on a system that is far from complete is very good. I was never expecting such excellent results on something that is not even fully complete.
The full system includes 3 generators, auxiliary power supply system, a reservoir, and a complete fuel control system taking direct control over the van's fuel pump and hho generators. For the van to run a full 7 minutes on one generator not even running at full capacity blows me away. I'm shocked at the results.
At one point while testing a different generator design I got about 12 minutes run time. I had a few issues with that one though. The generator that gives me 7 minutes run time is the most stable one.
Old Jul 6, 2011 | 03:35 PM
Kmega99's Avatar
Kmega99
The fuel line was depressurized during the test and I believe that the complete system will run much much longer.
72camperspecial
May 28, 2013 09:12 PM
Rudude8960
1983 - 2012 Ranger & B-Series
Feb 1, 2009 01:19 PM
mrjgp
May 24, 2006 07:56 AM
v8fiero
Aerostar
Dec 5, 2004 06:19 PM
jimbo81587
Electrical Systems/Wiring
Nov 18, 2004 02:32 PM
