tech question about tranny fluid type
Old Jul 2, 2011 | 04:19 PM
1955effie's Avatar
1955effie
Hi guys,
I just bought a 1996 F150 as a work /winter truck . It has the 300 six with a 5sp tranny and transfercase . What type of fluid / oil should I be using in it ? My owners manual tells me how much but not which type . I was told that the tranny was swapped out and a mazda put in but the NUMBERS on the tranny tell me that it might not be the case . ( although a garage slip shows a tranny swap )? The numbers are E4 and some other numbers after that . If I remember correctly the E should be 1980's ? I will be doing a tranny /transfer case service along with checking the front and rear diffs . So any info would helpful ... Thanks
Old Jul 2, 2011 | 04:45 PM
Lazy K's Avatar
Lazy K
For any 5 speed you should use automatic transmission fluid and the same for the transfer case. I know it doesn`t right but there it is.
ROKRAWL
Apr 7, 2013 10:04 PM
rustee90-150
Dec 21, 2007 03:09 PM
ford351c
Nov 20, 2004 07:47 PM
newtattoobob
1983 - 2012 Ranger & B-Series
Jan 15, 2003 10:21 PM
GringoRWB
Jan 31, 2002 11:50 AM
