headlight knob
Old Jul 2, 2011 | 11:10 AM
TXCITYDPS's Avatar
TXCITYDPS
headlight ****
How do you remove the headlight **** to get the instrument cluster trim off. The rest of the ***** just slid right off.
Old Jul 2, 2011 | 11:13 AM
Rogue_Wulff's Avatar
Rogue_Wulff
Reach up inside the dash, to the actual switch itself. There should be a little button on the side opposite of the wires. Turn the headlights on, push that button, and the ****/shaft should slide right out. You can then gently push it back in to turn off the lights.
Old Jul 2, 2011 | 11:15 AM
CaptainIPSC's Avatar
CaptainIPSC
There's a button on the top of the light switch. Reach up under the dash and feel for the button. It's kinda hard to get to but you should know it when you feel it. Once you find it lightly push/wiggle the button while pulling/wiggling the head light ****. When everything is right the head light **** and shaft will slide out. you might want to unhook the battery first cause you all your lights will be on when it's removed.
Old Jul 2, 2011 | 03:39 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The headlamp switch **** and shaft is a one piece assembly. Ford did not sell the **** by itself.
Old Jul 2, 2011 | 03:52 PM
montana_highboy's Avatar
montana_highboy
Depress the button depicted below....
Old Jul 2, 2011 | 04:33 PM
co425's Avatar
co425
Yeah and don't watch the **** up close while you pull. You'll punch yourself right in the throat. Did that myself on Thursday.
Old Jul 2, 2011 | 04:38 PM
TXCITYDPS's Avatar
TXCITYDPS
got it done, thanks guys
Old Jul 3, 2011 | 12:32 AM
460me's Avatar
460me
I really like the wiper ****,that one is fun to get off.
Old Jul 3, 2011 | 12:38 AM
Rogue_Wulff
Nah. A small allen wrench works wonders......
Old Jul 3, 2011 | 08:54 AM
460me's Avatar
460me
Good trick,I'll have to remember that one.
Monteg0
Dec 1, 2015 11:17 AM
DaveF-250SD
Nov 15, 2015 12:26 AM
Bird-Dog 250
Sep 13, 2015 12:11 PM
atomicjoe23
28
Jul 12, 2015 06:52 PM
