catalytic convertor -what will work?
Old Jul 2, 2011 | 03:19 PM
Rusty_Old_F250's Avatar
Rusty_Old_F250
I've decided I need to add a catalytic convertor to my truck- because it doesn't smell very pretty. I've had the carb tuned, timing and dwell adjusted, and it still dosen't smell very good- in fact it smells really bad. Any recommendations for a catalytic convertor that's compatible with a carburetor? The truck has the 390, 4spd, single exhaust (2 1/4 inch pipe) and stock 2100 carb.
Sam
Old Jul 2, 2011 | 03:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 1973 anything came with a cat converter. First installed in 1976 in certain vehicles (sold new in CA for example).
Why you would want to install one, I dunno. There is more to it than just the converter.
Old Jul 2, 2011 | 07:06 PM
Rusty_Old_F250
Well, I was hoping I would be able to install the cat and cut back on the smell, but I'm beginning to wonder if it could be other things contributing to it, like something wrong with the carb itself. I'm thinking maybe the power valve went ca-put (again) Do you have know of a source for them? The only way I have of getting them is in a carb kit, and I don't need more of those.
But I'm still interested in a catalytic, I've hard they have new high flow cat's designed specifically for carb'd engines, I thought it might be worth looking into.
Sam
Old Jul 3, 2011 | 02:32 AM
NumberDummy
I'm thinking maybe the power valve went kaput (again) Do you have know of a source for them?
1973 F250 390 2V M/T: Two possible enrichment (power) valves, as it depends on the carb ID tag number:
D3AZ-9A565-B .. Fuel Enrichment Valve / ID: Blue dab of paint (Motorcraft CE-101) / Obsolete
56 available NOS (none in the PNW).
D5TZ-9A565-A .. Fuel Enrichment Valve / ID: Pink dab of paint (Motorcraft CE-103) / Obsolete
59 available NOS, one in WA: VAN CLEVE FORD in Morton WA has ONE = 360-496-5999.
Old Jul 3, 2011 | 03:16 AM
Burburan's Avatar
Burburan
What is the smell? Does it smell like sulfer, unburnt fuel, oil?
Old Jul 3, 2011 | 07:24 AM
fmc400's Avatar
fmc400
MSEE
Catalytic converters are not intended to improve the "smell," in fact there's a decent chance it's going to smell just as "bad," or "bad" in a different way. What does it smell like? That's a sign something else is going on - anything to cover that up is just a band-aid for an underlying issue.
Most people's efforts are put toward how to get rid of them - not the other way around.
Old Jul 3, 2011 | 11:55 AM
Rusty_Old_F250
Thanks bill, I just might have to give them a call.
Right now the way it smells is like it's rich. I've adjusted the carb (even had someone else do it once) and it didn't make much difference. We leaned it out till it wouldn't idle any more then richened it up a quarter turn, just enough to keep it running.
Sam
1986F150six
20
Oct 3, 2018 05:23 PM
Zogman
Mar 22, 2015 09:53 AM
Tinterat
Jun 16, 2014 01:14 PM
Bonanza35
Jun 12, 2014 09:50 AM
AirSmitty
Nov 23, 2009 04:01 AM
