Wont start?
Old Jul 2, 2011 | 02:06 AM
Chief 88 f150's Avatar
Chief 88 f150
Wont start?
I have tried everything replaced the rear tank and sending unti, the fuel pump relay. I have spark cause i took the number 1 plug off and put on the throttle body. I am not gettin any power 2 either tank sending unit. truck turns over just as fast as it can. timing is good and firing order is right. Somebody help i wanna get my baby back on the road. is it a bad ground???
Old Jul 2, 2011 | 07:06 AM
subford's Avatar
subford
First try resetting the fuel shutoff switch. Just push the button down on top of it.
The switch is also called the Inertia switch.
Location of switch:
Old Jul 4, 2011 | 09:20 PM
Chief 88 f150
Yea I have tried a that a few times it just turns over and I get any power 2 those pumps.
Old Jul 4, 2011 | 09:21 PM
Chief 88 f150
I meant 2 say I can't get any power 2 the pumps
Old Jul 4, 2011 | 10:17 PM
subford's Avatar
subford
Does your fuel pump relay make for one second when you turn on the key and then drop out one second later?
Does the small black wire with a green stripe have a good connection (ground) to the NEG post of the battery?
Old Jul 5, 2011 | 06:14 AM
Chief 88 f150
Yea man it clicks but let me check that wire
Old Jul 5, 2011 | 06:25 AM
subford's Avatar
subford
If the green fuel pump relay clicks when the key is turned on then the small black wire with a green stripe has a ground at the battery.
Check the wiring under the green fuel pump relay socket and make sure all the wires are OK.
If so check the yellow wire under the relay and see if you have power on it at all times.
Old Jul 12, 2011 | 07:55 PM
Chief 88 f150
Yea man I checked everything all had power there is a white wire with a red stripe that broke off the left side of the block?
Old Jul 13, 2011 | 07:12 AM
subford's Avatar
subford
The white wire with a red stripe is an open ended wire, It is the STI wire.
Do you have power for one second at the Inertia switch on both wires when you turn on the key with a test light?
If so check the fuel tank selector switch on the dash.
Beastie
Mar 3, 2015 04:55 AM
Dcwhite232
13
Oct 15, 2014 03:06 PM
JamesHendrix
May 27, 2014 08:31 PM
Bagbyknoter
Sep 18, 2011 09:23 PM
gcfisher75
Dec 11, 2002 04:33 AM
