Fuel sending unit question
Old Sep 16, 2011 | 04:10 PM
Bagbyknoter's Avatar
Bagbyknoter
I have a new gas tank for my truck and need a new fuel sending unit as well.
Here comes the question. I wanted to know if there is any difference between a pre-feedback sending unit for a 300 and a feed back sending unit. Since i no longer have the feed back system i wondered if i could get away with the Pre-feedback sending unit.
Thanks,
Jonathan
Old Sep 17, 2011 | 07:49 PM
Franklin2's Avatar
Franklin2
Just look up a older truck and then your truck and see if the part numbers are the same. You can use autozone's or someone else's site to do it.
Old Sep 17, 2011 | 11:01 PM
custom1106's Avatar
custom1106
80-84 sending units are similar and use the smaller mounting hole, once you get to 85 the tank hole gets bigger. 86 is when the fun starts with more widespread use of EFI and in tank pump shenanigans.
Cruise through an LMC catalog, and you'll see just how many different senders are avail for these rigs, according to size of tank, location and year. To be honest, I don't think the feedback system had it's own special senders.
Old Sep 18, 2011 | 06:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
There are no differences between feedback and non-feedback.
However, along with the change in 1985 in the tanks and sending units...
The Front tank unit is different if it's 16.5 or 19 gallon.
If it's got EFI or not etc...
1987 and newer the sending units were changed yet again and will not work with our 1980-1986 fuel gauges.
What size tank or tanks do you have?
Long Bed: 19 gallons each tank
Short Bed: Front Tank 16.5, Rear tank: 19 gallons.
Old Sep 18, 2011 | 09:23 PM
Bagbyknoter
It is a long bed with one 19 gallon side mount tank
804wd832wdf150
Jul 6, 2018 09:12 PM
frito-bandito
30
May 14, 2014 07:56 AM
gravy31
May 12, 2013 09:46 AM
paintinpevs91
Feb 10, 2011 03:01 PM
doc54
13
Jun 8, 2008 08:13 PM
