Vaccuum Booster
Old Jul 1, 2011 | 12:57 PM
bradleydm's Avatar
bradleydm
Vaccuum Booster
The brakes on my 94 7.3 Turbo idi are soft and the pedal almost goes half way to stop. How do you know if it is the vaccuum pump, vaccuum booster or master cylinder that's causing the problem. Could it also be badley worn pads? Thanks for the help.
Old Jul 1, 2011 | 01:07 PM
Lazy K's Avatar
Lazy K
It is not the vacuum pump or the booster that is causing a low pedal.
The first thing you need to do is check that the rear brake shoes are good and properly adjusted up.
Old Jul 1, 2011 | 06:39 PM
oreocreaming's Avatar
oreocreaming
go to autozone and rent a vacuum tester OR just buy one. they are cheap enough. hook it up and see what kinda pressure your pulling. its usually the cause. when you switch to vent on your blower fan does it ever go back to defrost on its own? if so, then its the pump for sure.
Old Jul 1, 2011 | 07:44 PM
kenpobuck's Avatar
kenpobuck
As LazyK stated, low vac will not cause a soft pedal. It will make the pedal really hard to push. Soft pedal is cuase by many things, some of which are... bypassing master cyclinder, worn pads/shoes, improper adjustment of rear shoes, and possibly bad hoses at the front calipers or the rearend. The hoses will swell under the fluid pressure and possibly burst.
Old Jul 2, 2011 | 11:27 PM
Fatcatpaddy's Avatar
Fatcatpaddy
How much vacuum pressure should there be?
Old Jul 3, 2011 | 04:00 AM
Lazy K's Avatar
Lazy K
Should be 18in at least.
Old Jul 5, 2011 | 09:43 AM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
I have replace every single brake component on my truck except vac. pump and booster and my pedal is still soft. my vac. pump pulls 25 inch lbs @ idle.
Old Jul 5, 2011 | 12:10 PM
bashby's Avatar
bashby
An internally leaking RABS valve can cause it, did you already replace that?
Old Jul 5, 2011 | 03:31 PM
'94IDITurbo7.3
I have, yes.
I just bypassed it.
Old Jul 5, 2011 | 04:01 PM
Fordranchero's Avatar
Fordranchero
Bad vacuum pump makes very hard pedal, not soft.
I suggest you re-bleed everything and check master cylinder.
dumper
Large Truck
Nov 11, 2012 01:39 AM
Thomsen
Mar 18, 2004 01:13 PM
adelyser
1978 - 1996 Big Bronco
Jan 18, 2002 10:47 AM
fordsnharleys
Electrical Systems/Wiring
Oct 16, 2001 06:34 PM
